Briggs -stratton - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-08-2012, 12:15 PM   #1
Briggs -stratton
I have a 16 horse briggs single engine i cant get started.Spark is good.compression good,There is gas at carb but its not getting up to spark plug. What is wrong
lorjim is offline   Reply With Quote
Old 04-08-2012, 01:03 PM   #2
DIY staff
Rewards Points: 7,174
Have you tried starting it with engine starter spray?
(remove the air cleaner to try that)
If that gets it to start but it won't stay running---make sure that there isn't a gas shutoff in the fuel line---then plan on cleaning the float bowl of the carborator--
Look for a thread by Danger Mouse on this very subject---Mike---
Old 04-08-2012, 02:36 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by lorjim View Post
...but its not getting up to spark plug. What is wrong
are you sure? do you know how to hold the plug outside the motor to check?
if really no spark...
does the other end of that wire attach to a coil?
do you know what OTHER things might be on that circuit?
(eg: a kill switch)
Old 04-09-2012, 09:41 PM   #4
A Little Of Everything
Rewards Points: 1,364
Your carb is dirty. Your main jet is probably plugged - something that happens very easily.
DrHicks is offline   Reply With Quote
Old 08-08-2012, 08:12 PM   #5
can anyone help me out here i have a 2010 troy-bilt ztr riding mower with a 50" deck 26 horse kohler engine & electric pto was mowing yard last week & pto just stopped was still in engaged postion but blades stopped pushed in pto knob & tried too reengage but has not worked since any help with this problem would be very much appreciated
fpreuett is offline   Reply With Quote
Old 08-08-2012, 08:39 PM   #6
Rewards Points: 14,312
You did check to see that the belt is on all the pulleys that drive the blade and it's not broken, right?
Can only be about 3 differant things, bad PTO switch, disconnect the wiring where ever the conector is between the switch and the clutch and use an OHM meter to check for continuty.
Check all the wires to see if one got chafed between the switch and the clutch.
Briggs And Stratton Replacement Options timsmead Tractors & Mowers 13 04-30-2012 10:11 PM
Briggs and Stratton Engine pwgsx Landscaping & Lawn Care 16 12-29-2011 05:42 AM
Briggs & Stratton Fuel Problem/ No start rod46 Landscaping & Lawn Care 4 05-09-2010 02:53 AM
Briggs and Stratton generator part Jeremy Hillary Boob, PhD Electrical 3 01-10-2009 10:36 AM
Briggs & Stratton recall Big Bill Safety 2 09-28-2007 04:35 AM
