Best Gas Powered Lawn Edger Under $400 - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-04-2013, 07:23 PM   #1
Best gas powered lawn edger under $400
Hello,
I had a Craftsman gas powered edger for over 20 years. I think it needed repair twice (I babied it, changed the oil & filter, etc.) Finally I was told it needed a cabureator and that part was no longer available (after waiting 4 months). So I had to but a new one, and ended up with a Troy Built (I forget the model #). I may have just gotten a lemon, or perhaps the design was poor, but in the two years I owned it it was in the shop more than it was in my shed. I finally gave it away when i would have to spend more than I paid for it to repair it for the third time.
The pros and cons of the Craftsman and Troy Built
Craftsman - Blade did not rotate when raised
Troy - Blade always rotates
Craftsman - cutting depth was set by adjusting blade height (easy)
Troy - cutting depth set by wheel height (and kinda a pain to do)
Craftsman - ran well under varying loads
Troy - never ran right, always seemed like it was about to stall (even after two trips to repair center)
Craftsman - ran for 20 years
Troy - didn't make two full seasons (1 year warranty)
Any suggestions on a good edger, preferably with the features of the Craftsman (although I think they all adjust blade height by adjusting wheel height now).
P.S. I found a GREAT one for $1,000. I am trying to keep it under $400.
Thanx!
MikeyChris is offline   Reply With Quote
Old 04-04-2013, 08:17 PM   #2
Stihl fc90
j-easy is offline   Reply With Quote
Old 04-06-2013, 03:58 PM   #3
Too Short? Cut it Again!
I used to be them dozen at a time. Brand names changed but a good Briggs & Stratton used to work. I always looked for the sturdiness of frame, blade housing and shaft construction. Things can be dangerous.
Do you have a real outdoor lawn equipment store near you? I would be shopping there if you.
Or did you mean a gas-powered string trimmer?
Old 04-11-2013, 06:37 PM   #4
Rewards Points: 3,406
Echo PE225
http://www.homedepot.com/p/ECHO-21-2...-225/100663417
Forgot to say 5 year warranty on this one.
Canarywood1 is offline   Reply With Quote
Please help with my ridiculous front lawn slope billyh Landscaping & Lawn Care 14 05-20-2012 08:46 PM
What the hell happened to my lawn? (also: reseeding when weeds are present. N.Y.) Deck Landscaping & Lawn Care 14 05-24-2011 01:45 PM
New lawn + garden - garden is now a swamp Frozinite Landscaping & Lawn Care 8 09-15-2010 08:23 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 01:34 PM
lawn needs help ursula Landscaping & Lawn Care 9 01-31-2010 12:19 PM
