-   Tractors & Mowers (http://www.diychatroom.com/f106/)
-   -   Best gas powered lawn edger under $400 (http://www.diychatroom.com/f106/best-gas-powered-lawn-edger-under-400-a-176315/)
MikeyChris 04-04-2013 06:23 PM
Hello,
I had a Craftsman gas powered edger for over 20 years. I think it needed repair twice (I babied it, changed the oil & filter, etc.) Finally I was told it needed a cabureator and that part was no longer available (after waiting 4 months). So I had to but a new one, and ended up with a Troy Built (I forget the model #). I may have just gotten a lemon, or perhaps the design was poor, but in the two years I owned it it was in the shop more than it was in my shed. I finally gave it away when i would have to spend more than I paid for it to repair it for the third time.
The pros and cons of the Craftsman and Troy Built
Craftsman - Blade did not rotate when raised
Troy - Blade always rotates
Craftsman - cutting depth was set by adjusting blade height (easy)
Troy - cutting depth set by wheel height (and kinda a pain to do)
Craftsman - ran well under varying loads
Troy - never ran right, always seemed like it was about to stall (even after two trips to repair center)
Craftsman - ran for 20 years
Troy - didn't make two full seasons (1 year warranty)
Any suggestions on a good edger, preferably with the features of the Craftsman (although I think they all adjust blade height by adjusting wheel height now).
P.S. I found a GREAT one for $1,000. I am trying to keep it under $400.
Thanx!
j-easy 04-04-2013 07:17 PM
Stihl fc90
user1007 04-06-2013 02:58 PM
I used to be them dozen at a time. Brand names changed but a good Briggs & Stratton used to work. I always looked for the sturdiness of frame, blade housing and shaft construction. Things can be dangerous.
Do you have a real outdoor lawn equipment store near you? I would be shopping there if you.
Or did you mean a gas-powered string trimmer?
Canarywood1 04-11-2013 05:37 PM
Echo PE225
http://www.homedepot.com/p/ECHO-21-2...-225/100663417
Forgot to say 5 year warranty on this one.
