Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-25-2012, 11:26 PM   #1
B&S governor spring/throttle
]I have a briggs engine 12h802-2635 (goes on pressure washer). and just did a carb clean up(no screw adjustments) and got a new governor spring.new plug,filter,fuel,etc.It has a idle arm and a throttle arm.Am having trouble with readjusting the throttle/governor set screw and the spring..I have a high RPM when running and is tricky to get it set correctly.It wont work right with spring in gov arm-doesnt move throttle back and forth freely..any info on readjusting governor screw ,spring,and throttle?
Here are a few pics..
-also wondered about 2nd smaller hole (under throttle spring hook up) in close up pic
any info is appreciated
B&S governor spring/throttle-img_20120424_121512.jpg
B&S governor spring/throttle-img_20120424_121454.jpg
B&S governor spring/throttle-img_20120424_121444.jpg
B&S governor spring/throttle-img_20120424_121422.jpg
hidden1 is offline   Reply With Quote
B&S problems tc87 Tractors & Mowers 10 04-12-2012 09:01 AM
Small Engine - B&S 10.5 hp deanathpc Landscaping & Lawn Care 0 06-27-2011 02:56 PM
Can't start a B&S 8hp Chipper DonRav Landscaping & Lawn Care 5 02-17-2011 10:29 AM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 11:14 PM
B&S engine on Sears Tiller william duffer General Discussion 12 08-28-2010 09:00 AM
