Another Echo Trimmer Issue - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-30-2014, 04:07 PM   #1
jad
another echo trimmer issue
Have an echo GT225 and i get it to start but as soon as I even start to move the choke it stalls. I have cleaned and rebuilt the carb, fresh gas but still same problem.
What could be so sensitive that all i need to do is barely touch the choke lever and it cuts right out?
jad is offline   Reply With Quote
Old 04-30-2014, 04:31 PM   #2
Rewards Points: 34
Have you changed the fuel filter?
Dan
djlandkpl is online now   Reply With Quote
Old 04-30-2014, 04:39 PM   #3
jad
no I have not changed it.... I pulled it from the tank to look at it and it seems ok? I removed the clip holding the small piece of foam on the filter and the foam look clean but the filter itself looks like solid metal but I am sure its some type of filter. Can i try to run it without the filter just to test it?
Old 04-30-2014, 04:50 PM   #4
Rewards Points: 34
It can't hurt. I was chasing hesitation in my echo blower. It was the 2 year old filter.
Dan
Old 04-30-2014, 06:52 PM   #5
Rewards Points: 13,732
Something as simple as a plugged up gas cap. Simple to check, remove the cap to see if it run right.
Carbon build up in the muffler can also cause this.
Tom Struble (04-30-2014)
Old 05-01-2014, 11:52 AM   #6
jad
i had already checked the muffler screen it is clean, tried to run with removed fuel filter same thing....
it sure is showing symptoms of a fuel delivery issue but I am starting to wonder? Can it be something else causing it to cut out as soon as the engine tries to run a little harder? the trimmer is only 2-3 years old
Old 05-01-2014, 12:00 PM   #7
Rewards Points: 34
Originally Posted by jad
i had already checked the muffler screen it is clean, tried to run with removed fuel filter same thing.... it sure is showing symptoms of a fuel delivery issue but I am starting to wonder? Can it be something else causing it to cut out as soon as the engine tries to run a little harder? the trimmer is only 2-3 years old
Did you rule out the filter?
Dan
Old 05-01-2014, 12:06 PM   #8
jad
I remover the filter, and reinserted the tube back into the tank and started it....same problem.
I did see it gas flows back into the tank when I push the primmer bulb both with and with out the filter. not sure if that was any indication the filter was not clogged so I removed it and still same problem
Old 05-01-2014, 12:13 PM   #9
Rewards Points: 34
The primer does send gas back to the tank. Doubt it's the spark plug. Any chance the throttle cable is pinched or kinked?
Dan
Old 05-01-2014, 12:20 PM   #10
jad
yes primer sends gas back into the tank, I pulled the plug and it looks good.
throttle cable seems to be working fine, i had to disconnect it from the carb when I rebuilt the carb and it looked good.
I am stumped
Old 05-01-2014, 12:33 PM   #11
Home Remodeler
Rewards Points: 164
I would replace the spark plug. Cheap and you would know it was not the problem.
mikey48 is offline   Reply With Quote
Old 05-01-2014, 12:37 PM   #12
jad
would the trimmer still idle if the plug was bad?
Old 05-01-2014, 03:01 PM   #13
Home Remodeler
Rewards Points: 164
Anything is possible. Let us know how it goes.
Old 05-02-2014, 08:02 AM   #14
Rewards Points: 1,296
Since it runs on the choke, I am going to suspect a fuel delivery issue. Have you checked the fuel lines? If they get hard and brittle they can leak at the connections and the choke may be overcoming this issue
danpik is offline   Reply With Quote
Old 05-02-2014, 08:48 AM   #15
Rewards Points: 1,278
Have you checked the exhaust ports for carbon buildup?
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Tom Struble (05-02-2014)
Trane XR90 issue jasun HVAC 7 10-08-2012 06:18 PM
HVAC condensor fan outside intermittant wheelsup HVAC 21 05-24-2012 10:25 AM
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 05:50 PM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 12:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 06:49 PM
