5hp Yard Machine Snowblower - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 12-09-2012, 04:50 PM   #1
5hp yard machine snowblower
engine quits when you start to put it under load blowing snow idles fine back fires once under load
dagwood40 is offline   Reply With Quote
Old 12-09-2012, 08:58 PM   #2
Rewards Points: 13,300
And so far you have checked what?
When was the last time the carberator was rebuilt?
Changed the air filter?
Trying to use last winters fuel left in the tank?
Old 12-11-2012, 02:25 PM   #3
Bad gas
I found an easy way to check for bad gas: smell it. Smell good gas first and then smell the gas in your tank. You will notice the difference. I would recommend cleaning the carb, checking the air filter, draining the gas tank if it hasn't been used in a long time and replacing it with new gas as suggested.
sluggermike is offline   Reply With Quote
Old 12-12-2012, 11:30 PM   #4
Missouri Bound's Avatar
Does it run better when you choke it? Use fresh gas. If it runs better when you choke it after you put fresh gas in, the carburetor needs cleaning.
Do you want it your way or the right way?
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 01:07 PM
gas pressure line in middle of yard? BlueBSH Plumbing 2 08-01-2011 01:43 PM
MTD yard machine lawn mower qrilty Landscaping & Lawn Care 3 05-11-2011 06:52 PM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 11:03 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
