Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 12-09-2012, 09:37 PM   #1
5 hp B&S rototiller won't start
I know the gas is good because I used it the day before it stopped running. I tried squirting engine started down the carb and into the cylinder head. Normally in the past it would try to start. I checked the spark plug for a spark and noticed that it was giving a weak spark. I cleaned the magneto and the place it contact on the flywheel and then reset the gap using a business card. I then check the plug for a spark. The spark was still weak. I'm beginning to wonder if the magneto is bad, or if there is another contact like a ground that needs to be cleaned. A new magneto costs about $50 and so I'm not looking forward to replace it. Any ideas?
sluggermike is offline   Reply With Quote
Old 12-20-2012, 07:08 PM   #2
Central State Mower,LLC
Hi,
Although somewhat rare, I've had experiences in the past where a spark plug would fire weakly when removed and grounded to the engine block. When the spark plug was re-installed, the plug would not fire under compression.
If you haven't already done so, replace the spark plug...
Mark P.
Central State Mower, LLC
CStateMower is offline   Reply With Quote
Old 12-20-2012, 07:17 PM   #3
Can you post the numbers off the cowling?
If it was built before about '82 it may have points. They can get dirty and a bad condenser can cause a weak spark.
AandPDan is offline   Reply With Quote
compressor wants to start but won't wetbar HVAC 13 06-17-2010 07:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 02:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 09:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 11:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 08:05 PM
