24 H/p Running Rich - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-20-2012, 02:57 PM   #1
24 h/p running rich
hello gotta 24 h.p. briggs motor model446777, type 0244E1 not even sure what carb its got on it but when it starts it runs fine for bout 10 seconds, then it strats blowing black smoke runs real rough can even pull the deck into gear, the carb is the one that has the switch on the bottom of it if that makes any difference to anybody?? a while back it started to be starving for gas would only run with the choke out ! now getting to much gas
buckseight is offline   Reply With Quote
Old 06-20-2012, 03:24 PM   #2
Rewards Points: 78
In this order, I would clean or replace the air filter, per the manufacturer's recommendations, check that the carburetor mounting bolts or nuts are tight, check that the linkages are secure, and run some Sea Foam through it. If that doesn't work, I would remove and thoroughly clean the carburetor, and adjust it to the manufacturer's recommendations at that time, but count the turns on your idle screws, etc. first, so that if it does not run you can at least return to where you are at now.
Sound of Water Running in Pipes rpishotti Plumbing 4 12-06-2010 12:09 AM
Basement *VENTING* AND running entire new drain lines. 57_Hemi Plumbing 6 09-30-2010 09:00 PM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 09:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
