2 Cycle Engine Fuel Line Problem - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-30-2012, 03:42 PM   #1
2 Cycle Engine fuel line problem
New to forum, so Hello, everyone!!!
Now my problem. The fuel pickup tubing inside the gas tank of my gas powered edger finally fell apart. I replaced it. But now, when I press the primer button, I'm not getting any fuel flowing from the gas tank into the lines. Bulb is not cracked, I've checked. My question. there's a second line going to the tank from Carb. Does it need to be deep enough in the tank to be covered with gas? Reason I ask is that when I cleaned out the tank, I found 2 broken pieces of tubing.
Even without priming, the motor will start with full choke, but after starting and running in full chock, when I move to half choke, motor dies.
JLC1950 is offline   Reply With Quote
Old 07-31-2012, 04:21 AM   #2
An old Tradesmen
Rewards Points: 7,414
Moved to Tractors and mowers forum.
Old 07-31-2012, 07:50 AM   #3
A Little Of Everything
Rewards Points: 1,364
It sounds like you've got a tiny air leak somewhere in that line, or the primer bubble.
Or...
My understanding is that one of those little lines is the "choke side" and one is the "throttle side" for the carb. Both need to be in the gas, to avoid pulling in air.
DrHicks is offline   Reply With Quote
Briggs & Stratton Fuel Problem/ No start rod46 Landscaping & Lawn Care 4 05-09-2010 02:53 AM
Problem with Main Line or Not? reibuild Plumbing 2 05-02-2007 10:41 AM
air in fuel line pingers7 HVAC 2 01-28-2007 06:41 PM
Engine Slowly Loses Power and Dies While Driving slickshift Automotive Repairs 16 01-15-2007 11:34 AM
Small engine problem rkhpapa General DIY Discussions 1 12-09-2006 08:00 PM
