Xypex Or Other Sealant For Foundation Leaks - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-07-2012, 08:25 PM   #1
Rewards Points: 24
Xypex or other sealant for foundation leaks
In heavy rain, water leaks from four or five spots in the uphill side of the foundation of my San Francisco row house, and runs in little streams along the concrete basement floor.
The house is built on a hill, and the leaks are only on the side of the foundation that face uphill. There is no gap between my roof line and the roof line of the neighborhood immediately uphill from me; there is no place for rain to enter between our houses, at least from above.
The foundation is of the 'concrete perimeter' type, according to the house inspector, and doesn't have reinforcing steel.
I asked a local contractor about this problem. He suggested I look into Xypex, but sounded a little pessimistic about how long the Xypex treatment would last, and said he could offer no guarantees that the Xypex application would stop the leaks.
Does anyone on this forum have experience with Xypex? Or can you recommend another product or treatment for dealing with these leaks?
For what it's worth, there are no living quarters in the basement, and the water from these leaks only runs on the concrete floor, without touching the wood of the frame. The leaks are annoying, but I probably could live with them, if I had to.
MidgeTenant is offline   Reply With Quote
Old 06-15-2016, 07:42 AM   #2
Rewards Points: 42
Re: Xypex or other sealant for foundation leaks
Google "Purchase Xypex". The purpose is to hit sites that sell the product and read the reviews (Lowe's, Home Depot, Amazon). You will also be able to view similar products and read their reviews. I stay away from company sites. They are trying to sell a product and will always sound positive.
If possible try to find out what the "active" ingredient is. Somewhat like purchasing a generic drug. Both have the same active ingredients, but the brand name is alway more expensive.
MissyBrown is offline   Reply With Quote
Old 06-15-2016, 09:48 AM   #3
Rewards Points: 1,476
I would try googling "Xypex reviews".
mikegp is offline   Reply With Quote
Old 06-20-2016, 06:58 AM   #4
Rewards Points: 4,732
xypex is primarily used for vapor transmitted remediation - you have active leaks - that's different - we wouldn't choose zypex,,, IF it were to work, which i doubt, wtr still penetrates the wall til its stopped by a barrier,,, when that happens, damage occurs to the wall's material however you don't know it til the wall fails & the hidden damage is apparent
waterproofing is always done from the positive side rather than negative
ABS drain pipe leaks under pressure test abracaboom Plumbing 12 01-24-2012 07:27 PM
3 season room roof leaks rod altman Carpentry 7 12-22-2010 09:56 AM
Countertop sealant leaves granite with a dull finish? HeyItsJoel Tiling, ceramics, marble 6 05-31-2010 06:00 AM
Can I use this sealant (3M FD150+) on Class B flue? KatieAK Building & Construction 1 04-12-2010 04:35 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 09:09 PM
