Would 3 Or 4 Yards Of Concrete Cover A 12x20 Garage? - Concrete, Stone & Masonry - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-21-2012, 08:08 AM   #31
Rewards Points: 150
Thanks for the advice, Mike it was really helpful.
CJIII is offline   Reply With Quote
Old 12-21-2012, 08:41 AM   #32
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Mike that is a good idea, I see why you make the big bucks now.
CJ, when you pour your slab are you going to do a monolithic slab (thick edge slab) That would be the easiest for you. Be sure to put reinforcement concrete wire and 6 mil poly, termite treatment and post hole every 4 feet on center down to solid ground. You might want to think about stubbing out for water and future electric in your slab. For sure if you are coming in underground with the electrical, be sure to install a pipe for the wire to come up in the wall. Here is a sketch of a monolithic slab.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-21-2012, 09:17 AM   #33
Rewards Points: 150
Yes Jim, thats what we do in Alabama is a monolithic slab.
The Following User Says Thank You to CJIII For This Useful Post:
BigJim (12-21-2012)
Old 12-21-2012, 09:37 AM   #34
Rewards Points: 150
Mike, I am CJ21 over at CT!
oh'mike (12-21-2012)
Garage concrete block foundation on slope gopherdad Building & Construction 3 07-30-2011 01:23 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 08:31 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 04:13 AM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 01:11 PM
