Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-18-2012, 06:04 PM   #1
Would 3 or 4 yards of concrete cover a 12x20 garage?
I am wondering would 3 or 4 yards of concrete cover a 12x20 garage foundation with a 12''x12'' footing?
CJIII is offline   Reply With Quote
Old 12-18-2012, 06:07 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Do the math,... a yard of concrete is 27 cu. ft....
12'x 20'x how many inches,..??
Old 12-18-2012, 06:13 PM   #3
Civil Engineer
For the footing, each linear foot requires 1 cubic foot of concrete. You have 60 linear feet of footer, hence 60 cubic feet required there. The slab is 240 square feet, so for a 4 inch thick slab you would need an additional 80 cubic feet of concrete, for a total of 140 cubic feet, which is a little over 5 cubic yards. Due to spillage and waste, best to order 6 yards of concrete. Unless of course your slab is not 4 inches thick, in which case you need to modify the computations.
Old 12-18-2012, 06:18 PM   #4
Yes the slab is 4'' thick.
Old 12-18-2012, 07:53 PM   #5
I personaly would never suggest anyone DIY there own slab. Seems ike a simple job, but it's not.
It's a one shot deal, once that truck pulls in there is not do over or just make it work.
Even the lay out, footings, height of the slab, the slope toward the front can be tricky.
Have you taken into consideration that the bottom row of siding needs to be at least 6" off of grade?
Have you concidered using stem wall constrution?
concretemasonry (12-18-2012)
Old 12-18-2012, 08:30 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
4" slab on a 12 x20 works out to .3333x12x20 / 27 +10%= 3.256 yrds round up to 3.5 yrds if you can get 1/2 yrd ordered otherwise get 4
woodworkbykirk is offline   Reply With Quote
Old 12-18-2012, 10:20 PM   #7
concretemasonry's Avatar
Better to order too much since concrete is not that costly once you reach the minimum delivery amount. Nothing is worse than coming up short if you did not have base under the slab graded as accurately as you want you pencil will be in figuring costs in advance.
Plan ahead and make sure you have something formed in advance that you ultimately need - sidewalk, apron, etc. to use up any excess. Much better than just dumping it in the wrong place.
the biggest mistake with concrete pours is to not have enough (poor concrete job with cold joints) or enough help to place it quckly if the weather turns. - Also have protection for rain or snow.
Dick
concretemasonry is online now   Reply With Quote
Old 12-18-2012, 10:27 PM   #8
I understand that pour concrete is not a DIY job, thats why I thought about doing a wooden floor.
Old 12-18-2012, 10:49 PM   #9
I figure it was 4 yards.
Old 12-18-2012, 11:00 PM   #10
STAFF
BigJim's Avatar
CJ, It would be a little over 3.5 yds for just the slab, but you said you were pouring 12X12 footings so you will need at least 6 yds like Daniel said.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
PaliBob (12-19-2012)
Old 12-18-2012, 11:20 PM   #11
JOATMON
ddawg16's Avatar
Are you pouring that with a totally flat floor? No stem wall?
For reference, my floor is 20x25....it took 20 yards of concrete.....oh, the footing is 18"w x 24" deep and has an 8"h x 6"w stem wall all the way around. I love that part...it gets my walls at least 8" above the ground and on the inside....all my cabinets sit on the lip of the stem wall anchord to studs....nothing touches the floor....makes it easy to wash out the floor.
If you want to see pic....click on the garage build link in my signature.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 12-19-2012, 12:07 AM   #12
Ok thanks!
Old 12-19-2012, 12:10 AM   #13
The reason I wont concrete is that I will be using the garage as a woodworking shop!
Old 12-19-2012, 12:18 AM   #14
Going to be tight in that small an area trying to use it for a wood working shop.
Have you done a simple lay out on some graft paper to see how it's going to look.
Just been there far to many times. Built the garage, moved eveything in, find out it's to small and have to go back to working outside.
Old 12-19-2012, 12:29 AM   #15
I know its small but my current shop is 10x12 shed.
Garage concrete block foundation on slope gopherdad Building & Construction 3 07-30-2011 02:23 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 09:31 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 05:13 AM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 02:11 PM
