Woodstove Platform Questions - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-19-2012, 09:33 PM   #1
Talking
Hi Everyone
I'm in the process of installing a woodstove in my (new to me) home. I've got Terrazzo Tile on the floor, so I realize I don't REALLY need a "hearth pad" or a platform. But i think esthetically, it'll be more pleasing to raise the stove UP a bit. So I have a few options. The obvious one being = build a wood platform with 1/2 inch plywood and 1/2 durarock with hearth stone on it. But, would it be LESS expensive and MORE expedient to create the pad with concrete block, fill it with cement and cover THAT with durarock? I'm leaning towards that...but then...how to adhere it to the wall/floor? I'd rather NOT start drilling holes in the floor. And, tho' codes differ I'm sure there are similarities...would cement block beneath meet code?
I'd be interested to hear what you'all think will be more economical and if speedier...so much the better.
thanks in advance for your imput.
minstrel
Minstrel458 is offline   Reply With Quote
Old 12-20-2012, 10:38 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Originally Posted by Minstrel458 View Post
Hi Everyone
minstrel
Ayuh,.... My question is Why attach it at all,...
Gravity will hold it in place, just fine...
Old 12-20-2012, 10:41 AM   #3
Rewards Points: 12,868
Your right, a platform is not even needed.
I'm not following the whole concrete block idea.
A simle 2 X platform with 3/4" not 1/2 Advantec subflooring on top of it and cover the whole thing with 1/4 tile board would be pretty easy.
I'd just use long screws and attach the part that's near the wall to the studs and or bottom plate.
With all that weight it's not going any place.
Old 12-20-2012, 11:49 AM   #4
Rewards Points: 4,454
weight is a great quality especially when combined w/gravity - even oprah & whoopie won't move it much
Old 10-17-2014, 10:19 AM   #5
Rewards Points: 44
Aside from the aesthetics of a platform, the Advantec may also serves as a heat shield. Does anyone know how one would make the side tile walls with airspace before studs to meet fire code requirements for a traditional wood burning stove?
kurtp2 is online now   Reply With Quote
Old 10-17-2014, 11:40 AM   #6
Rewards Points: 114
Advantec is NOT a heat shield when used in a wood stove installation. Not not not.
And there is no such thing as a single installation guide for. A "traditional wood burning stove". Stoves are all different in terms of clearances from combustible surfaces in back, each side, and bottom. There ARE standard "if your stove isn't listed do this to be safe" guidelines......that are basically 36" from combustible walls.
As an example, my stove is like 8" from a wood paneled wall.....because there is a metal heat shield installed 4" off of the stove back. And I am within 4" of the floor...because there is also a heat shield installed 2" off of the stove bottom PLUS there is a "stove pad" made up of 24 gauge steel covered by 1/2 inch cement board covered by ceramic tile.
So, look up your stoves specs and requirements on the internet and follow them. And don't forget that fire code will require you to have carbon monoxide and smoke detectors also. Ron
ront02769 is offline   Reply With Quote
Old 10-17-2014, 04:06 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
You might want to check with your insurance provider also, some won't insure with wood heat.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-18-2014, 02:06 PM   #8
Fixing a Fixer Upper!
MaryAguila's Avatar
Rewards Points: 54
We are looking at getting one of these (URL removed) Does anyone have any experience with this brand?
MaryAguila is offline   Reply With Quote
Tags
concrete block , durarock , hearth pad , platform , woodstove
Mobile Home Carpentry questions immeraufdemhund Carpentry 3 11-19-2010 07:52 AM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-25-2010 12:53 AM
Some Questions Derickb Electrical 5 05-12-2010 03:11 PM
A few roof questions before I begin... chrisexv6 Roofing/Siding 6 05-02-2010 07:16 AM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
