Wood Paneling Over Stucco - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-28-2013, 01:52 AM   #1
Rewards Points: 37
Wood Paneling over stucco
The sliding door in our living room leads to a sun room that was added on in the back yard. Therefore, one of the interior walls is a stucco wall. we are thinking of covering this wall with aged/distressed wood paneling... maybe old wood from pallets or anything we can get our hands on.
What would be the best way to attach it to the stucco?
I was thinking of just using something like liquid nails or some other adhesive to stick it directly to the stucco... or maybe furring strips? If furring strips, what would be the best way to attach the strips to stucco?
any thoughts?
Thx
joshik is offline   Reply With Quote
Old 07-28-2013, 06:39 AM   #2
Rewards Points: 4,750
what's behind the stucco ? then again, its always a boon to know where your ' WHERE ' ( not just the sun room ) is so responders can give the best advice
Old 07-28-2013, 07:08 AM   #3
Rewards Points: 14,026
100% sure you really want to do it that way?
What's the texture on the walls like.
Got a picture of the room?
Just glue is not going to work, when building out the wall like your suggesting it would involve redoing all the trim, adding jamb extensions to all the door and windows.
Not my first choice but rustic paneling would be a whole lot less work.
Old 07-28-2013, 11:30 AM   #4
Rewards Points: 37
not sure what is behind the stucco aside from the wood framing. do they usually lay plywood under stucco? btw, im in San Diego, CA.
the texture is pretty rough. I was thinking liquid nails (or something similar) would work bc it wouldnt be a whole lot of paneling.
as for jamb exentions. i was thinking of using thinner pieces of wood to frame around the sliding door and window.
here are some pics
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
drywall on wood paneling framing anuvanoob Drywall & Plaster 14 09-18-2012 01:14 PM
Can I put old removed wood paneling over joist in attic timmay_8 Building & Construction 6 12-15-2011 02:40 PM
can you have fresh sawn wood for paneling? 4just1don Building & Construction 1 10-07-2009 09:18 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
