Wood Gate In CMU Pillar? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By diyer75
Old 01-06-2017, 04:24 PM   #1
Rewards Points: 12
Wood Gate in CMU Pillar?
Hi,
I just had this Breezeblock fence built in front of our house to create a front courtyard and more privacy.
I am going to build my own gate which seems pretty simple and straightforward but I am not sure of the best direction to take in attaching it to the pillar.
Should I:
A) attach a wood post on either side (which I guess I need to do since I want this to have a handle and latch anyway) and attach the wood post to the brick pillar with EPOXY/GLUE and/OR Anchor bolts? Each pillar is filled with concrete and rebar.
or
B) attach the gate with hinges directly to the concrete pillars??
Any advice on the type of wood to use if I should go that route, and how to best attach it, would be appreciated.
The gate size will be 4' wide x 6'2" high leaving about 4" at the bottom to open and close.
Thanks!
diyer75 is offline   Reply With Quote
Old 01-06-2017, 04:40 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Re: Wood Gate in CMU Pillar?
How heavy is the gate going to be? A wood post will likely have more success not wiggling loose from the block if it is glued and screwed to the block and sunk in the ground and concreted in.
Bondo likes this.
Old 01-06-2017, 04:43 PM   #3
Rewards Points: 12
not sure how heavy it will be but probably heavier than most as I'm using 2 x 6's instead of 2 x 4' for the construction of the gate then on top of that rathe than using wood slats I'm using marine grade plywood and then painting it all.
also the wood pillars ideally don't have to go into the ground as it's concrete there I guess I could use anchors there and screw those into the ground then into the wood then then wood into the concrete pillars??
thanks for your help!
Old 01-06-2017, 05:38 PM   #4
joed's Avatar
Rewards Points: 13,750
I would use 2x4 or 2x6 to match the gate. Mount them to the pillars with concrete wedge anchors.
The Following User Says Thank You to joed For This Useful Post:
diyer75 (04-17-2017)
Old 01-06-2017, 10:42 PM   #5
Rewards Points: 12
ok i will use 2 x 6"s on either side of the gate opening and anchor them into the concrete pillars with the concrete wedge anchors then i'll install the hinges to that and the door latch/lock assembly.
thanks !
stadry likes this.
Old 01-06-2017, 11:12 PM   #6
Rewards Points: 2,090
I like a good functional sliding gate. They kind of stay where they are needed rather than swinging out in the way where they aren't needed too much.
Old 01-08-2017, 12:07 PM   #7
Rewards Points: 4,806
gate out of p/t'd 2x6's won't be significantly heavier than p/t'd 2x4's,,, wouldn't pick plywood' - even marine grade,,, suggest 3/8" anchors into mortar jnts rather than into cmu's
would be helpful to post where YOUR ' where ' is located when asking
The Following User Says Thank You to stadry For This Useful Post:
diyer75 (01-09-2017)
Old 04-17-2017, 06:58 PM   #8
Rewards Points: 12
I'm in Dallas. I've decided to use IPE instead of plywood! Although I might use cedar.
Tags
attachment , concrete , fence , gates , masonry
Wood fence with steel posts gate question. dabeast Building & Construction 8 06-25-2016 01:44 AM
Need help identifying stained pallet wood. (pics) zpafk6 Carpentry 9 02-16-2016 08:41 PM
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Help with wood fence gate replacement DEL82 Landscaping & Lawn Care 3 07-05-2015 05:18 PM
Is this normal??? Exposed wood near foundation of house? simiesue Building & Construction 19 01-04-2012 10:01 PM
