Wire Or Rebar In Patio - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-12-2012, 06:10 AM   #1
Wire or rebar in patio
Is it better to use wire or rebar in a 14 x 32 concrete patio? Live in northern Indiana and water doesn't drain well from yard after raining or the snow melts away.
jajowhite is offline   Reply With Quote
Old 05-12-2012, 07:27 AM   #2
Ravenworks's Avatar
Wire is fine as long as it is installed right,most times it gets left on the bottom,it needs to stay elevated.
Ravenworks is offline   Reply With Quote
Old 05-13-2012, 02:53 PM   #3
Rewards Points: 4,796
raven's right - even aci doesn't recommend any wire/steel UNLESS there's 2" below & above it,,, think the spec reads ' midpoint vertically in a slab +/- 5% - in a 4" thick slab, that equates to .2" - no one can be that accurate. you're far better off placing the conc & installing the proper joints at the correct time,,, fyi, wire mesh adds strength while the green conc is in tension ONLY,,, after the conc cures, all it does is hold the broken pieces together usually the broken pieces are caused by an incorrect joint pattern/size/depth
Old 05-13-2012, 04:19 PM   #4
Rewards Points: 152
You dont have to use wire if you build a proper base by putting down 3" of crusher run and 1" of fill sand. Tamp thoroughly. Along with proper cut joints, this will increase the life of your concrete.
GL
TRUEPRO is offline   Reply With Quote
Old 05-13-2012, 05:51 PM   #5
Ravenworks's Avatar
Originally Posted by TRUEPRO View Post
You dont have to use wire if you build a proper base by putting down 3" of crusher run and 1" of fill sand. Tamp thoroughly. Along with proper cut joints, this will increase the life of your concrete. GL
Crusher run for a base is good I would use 57 gravel on top of that for a break, enabling the pad to move with the seasons
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 12:51 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 10:48 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
