Winter Thaw Leaking In Cellar Basement Stairs. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-31-2013, 07:43 PM   #1
Winter thaw leaking in cellar basement stairs.
It looks like the water is seeping up into the concrete stairs. The section that is about 4' thick is all wet as well as the two stairs. Any ideas on how to repair this?
brcr is offline   Reply With Quote
Old 01-31-2013, 07:51 PM   #2
Rewards Points: 1,494
Eliminate water pooling up against the foundation.
Install a perimeter drain system below basement floor level (and lowest stair step level) with sump pump.
Old 02-01-2013, 09:39 AM   #3
Rewards Points: 4,578
winter thaw or not, its still water & rain'll also seep down & leak in the same weak spot,,, think of your very fine bsmt as a ship's hull below waterline & it becomes more clear,,, its always better to prevent wtr from entering than managing once its inside,,, how far below exterior grade is it showing up inside ? thyen again, it it can't enter where it is not finding an opening, it will show up somewhere else,,, proper grading & gutter discharge are the 1st things to ck.
usually ' seeping up ' = wtr seeking its own level altho it could be hydrostatic pressure,,, ' about 4' thick ' isn't much data nor is ' as well as the two stairs ' - more ideas to follow as more inf is post'd , , , , ,
Old 02-21-2013, 11:09 AM   #4
You have two possible options - one would be that there is a hole at the top of the stairs and water is rushing down and leaking up around the stairs, this can be fixed by simply filling that void with some sort of loosely mixed concrete mixture. - two would be that you have ground water that is forcing it's way up and if that's the case you may need to have the steps taken up, drainage installed and then the steps would be have to be reformed.
-Ameri-Dry Guy
Ameri-Dry Guy is offline   Reply With Quote
Old 02-21-2013, 05:06 PM   #5
horsepuckey ! IF you like drylok: DryLok was holding my foundation together?
The Following User Says Thank You to stadry For This Useful Post:
bbo (02-21-2013)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 09:13 PM
Basement egress stairs June Benninger Building & Construction 0 08-07-2010 01:54 AM
Need Advice on how to complete basement stairs. Bakuto Building & Construction 11 04-05-2010 09:37 PM
Cold Room in Finished Basement Creekbender Building & Construction 4 01-31-2010 08:54 AM
