Wide Flange Beam Penetration Through Brick - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-21-2012, 01:24 PM   #1
I have a condition on a building where a WF Beam is going to penetrate the structural brick wall perpendicularly. Does anyone have a best practices detail to close in the steel flange to create a boxed beam for a perimeter caulk bead. Better idea?
remace is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 08:39 AM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 02:22 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
Ridgevent solution for a wide ridge beam daveskee Roofing/Siding 12 12-02-2010 09:13 AM
