Who Tuck Points A Chimney - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-04-2014, 10:32 PM   #1
Lord of Slums
Rewards Points: 1,974
Who tuck points a chimney
Should I call a roofer or mason. Do masons do the flashing as well. I had a mason look at the chimney, he said to pick out what was loose and redo the space between the bricks. Acro something 60, something about a milky white bonding agent. The red flag was the mason was telling me the wrong way to flash a chimney. The next red flag was the price was way to low.
mj12 is offline   Reply With Quote
Old 05-05-2014, 12:22 AM   #2
Rewards Points: 6,652
Who do you think? Your last sentence clues you in that they know more then a roofer. As for what you are stating a Red flag for the price too low. How much are you looking at spending on this job?
Old 05-05-2014, 05:31 AM   #3
Rewards Points: 4,744
masons usually install flashing - you just happened to call 1 who isn't well-versed in repair methods,,, nowadays roll alum is often used - find a guy who knows lead & how to use it,,, 'acryl' is probably what he meant - its an additive to mortar
oftentimes a good roofer will also possess the necessary knowledge & skills
irc
The Following User Says Thank You to stadry For This Useful Post:
jomama45 (05-05-2014)
Old 05-05-2014, 08:05 AM   #4
Rewards Points: 1,232
Chimney sweeps do repairs, they are equipped to work on roofs which a lot of masons are not, and if they are worth a damn, they know how to flash as well.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
tuck point a inside decaying chimney base ezj001 Building & Construction 2 09-04-2010 10:49 AM
Tuck point or rebuild chimney? jane99 Building & Construction 2 05-18-2010 01:12 PM
