White Spots On Newly Poured Driveway - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Register Blogs Articles Rewards Today's Posts Search
Old 10-23-2013, 08:05 PM   #1
Rewards Points: 29
White spots on newly poured driveway
Hi all,
I had a concrete driveway poured about 48 hours ago and it currently has white spots and blotches as indicated by the picture below. Is this at all normal? Thanks for your help.
tbick is offline   Reply With Quote
Old 10-23-2013, 08:26 PM   #2
Rewards Points: 6,652
Nothing to worry about. Typical for fresh concrete to do that, as it is drying and going through the hardening process. See it more with colder nights. Why isn't it covered with a tarp & straw to help hold the heat in, while it finishes hardening this next ten days?
Old 10-23-2013, 08:57 PM   #3
Rewards Points: 29
Thanks for the reply gregzoll. Good to know it's normal. Unfortunately I don't know much about concrete and the contractor did not give me instruction on curing. I'll give the tarp and straw method a try.
Old 10-23-2013, 09:02 PM   #4
The contractor should have taken care of that, if they were watching the temps. Unless your area was not going to go into freezing temps, like it is doing elsewhere, that may be why they did not tarp & place straw over the tarp, to help hold the heat in from the curing process.
Old 10-24-2013, 07:01 AM   #5
Concrete & Masonry
Rewards Points: 96
Completely normal. Nothing to worry about.
I wouldn't take gregzoll's advice on covering it with straw and plastic as this point either, unless you really have nothing better to do with your time..........
jomama45 is offline   Reply With Quote
Old 10-24-2013, 10:26 AM   #6
Rewards Points: 29
Thanks for the help guys. And it should stay just above freezing the next couple of nights.
Old 06-04-2014, 10:01 AM   #7
Same issue.
I think I have the same issue here. I looks like the concrete started to set up before the did the final finishing and the aggragate didn't get far enough down into the concrete.
My concern is that the white spots will get brittle and crack out leaving a very rough surface.
I poured 70 of sidewalk and a 20x30 pad and most of it has the same look. The side walk is the worse. @ other pads 7x7 that were poured looked all dark gray.
Any advice? Is this normal?
White spots on newly poured driveway-20140604_063442_resized.jpg   White spots on newly poured driveway-20140604_063225_resized.jpg
psu94psu is offline   Reply With Quote
Old 06-04-2014, 10:33 AM   #8
Rewards Points: 4,810
Read jomama45 post, it's normal.
Canarywood1 is online now   Reply With Quote
Old 06-04-2014, 03:04 PM   #9
Rewards Points: 29
That's what mine looked like for a couple of weeks and it turned out fine.
Old 06-04-2014, 03:37 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The white spots are large pieces of aggregate that aren't holding as much moisture as the mix is holding. Give it time it will all match up in a few weeks depending on your weather.
The aggregate is kind close to the surface but it isn't going anywhere. I personally would have pushed the aggregate a little deeper below the surface but no real harm in what you have there.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
gregzoll (06-04-2014)
Old 06-04-2014, 05:26 PM   #11
Rewards Points: 526
using a roller screed or vibrating screed would've resolved that issue but its rarely seen on residential work,,, it all looks right-side-up from here
irc
stadry is online now   Reply With Quote
The Following User Says Thank You to stadry For This Useful Post:
Old 06-04-2014, 05:48 PM   #12
irc
The Cement contractors in my area will do a roller or vibrate screed. Every job they do comes out looking perfect. There are only a couple of companies in my area that do Patio, Sidewalk or Driveway work. Every job they do is perfect with no problems.
Especially when they do the Stamped jobs.
Old 06-04-2014, 08:46 PM   #13
And lacking either of those tools, a bull float in the proper hands can achieve the same result.
The Following 2 Users Say Thank You to Canarywood1 For This Useful Post:
Old 06-04-2014, 09:18 PM   #14
Only in the hands of the person that knows how to properly use them.
Old 06-04-2014, 09:55 PM   #15
Msradell's Avatar
Rewards Points: 202
Very True! In other people's hands they can be very detrimental to the finished product.
Msradell is offline   Reply With Quote
White dusty spots on dark blue wall!!!!!!!!! Patsfan34 Painting 41 05-26-2015 05:41 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Painting white martinigirl Painting 3 04-26-2009 06:24 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 07:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
