Where Can I Buy Dimpled Membrane - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-23-2012, 01:17 AM   #1
Where can I buy dimpled membrane
I'm having a heck of time finding a retailer of dimpled membrane. I am making repairs/retro fitting my basement wall in an attempt to stop a water leak. I plan to excavate, reroute water flow from yard run off and gutters, and seal the basement walls.
Does anyone know of an online retailer for dimpled membrane such as Delta DS or Certainteed Platon? I have been searching the interwebs for about 3 hrs.
Thank you
RockingM82 is offline   Reply With Quote
Old 07-23-2012, 06:35 AM   #2
Trucon01's Avatar
Rewards Points: 510
Please keep me posted on this. I've also asked the same thing on one of my posts. I found a place online that sells it, but you have to buy a minimum of the product which is way more than I would need.
Good luck
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 07-23-2012, 06:49 AM   #3
I have found the Platon at Menards. They have it listed as a de-coupler for flooring, but if you read the description it is also for use on exterior foundations. The only problem with Menards is you can't order the Platon Plugs and have them shipped to your home. You can order the membrane but not the fasteners. I'm going to call them today during business hours and ask if there is any way they can ship them. The nearest Menards to me is over 2 hours away.
http://www.menards.com/main/search.h...goryHierarchy=
Old 07-23-2012, 07:01 AM   #4
Trucon01's Avatar
Rewards Points: 510
Well, I'm probably going to call a place today who is a distributor for Delta-MS.
Potomac Valley Brick
Ph: 1-301-309-9600
Note: DELTA®-MS, DELTA®-DRAIN, DELTA®-FL, DELTA®-DRY
Spycore looks like they may sell the fasteners??
http://www.spycor.com/DELTA_MS_found...tem_p/dlms.htm
Leaks in membrane roof at posts and edge leakhelp Roofing/Siding 13 09-09-2012 07:22 PM
Keraflor for Kerdi membrane myfirstbathroom Tiling, ceramics, marble 9 04-20-2011 01:21 PM
Torch on roof membrane on deck canada55 Roofing/Siding 36 03-03-2011 02:18 PM
Basement Sump Pump & Dimpled Plastic Membrane Interior Questions cloves Building & Construction 0 03-24-2010 09:44 PM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 05:16 PM
