Whats An Appropriate Infrared Temp Gun, For Checking Concrete Temp For Sealing? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-23-2016, 02:31 AM   #1
Rewards Points: 288
Whats an appropriate infrared temp gun, for checking concrete temp for sealing?
Have a few concrete sealing jobs lined up, and possibly a few more. Cold temps now, so want to make sure the concrete is at the appropriate temperature, by using an infrared temperature gun. Does this require anything fancy, or would a middle of the road gun be sufficient? For instance, something like this highly reviewed one:
https://www.amazon.com/Etekcity-Lase...emperature+gun
Thanks!
tireshark is offline   Reply With Quote
Old 12-23-2016, 03:11 AM   #2
Rewards Points: 370
Re: Whats an appropriate infrared temp gun, for checking concrete temp for sealing?
I bought an infrared gun to check temps in kitchen hoods. I used it and then found it was only good for 3 foot distance, maximum.
fireguy is offline   Reply With Quote
Old 12-23-2016, 10:44 PM   #3
Msradell's Avatar
Rewards Points: 84
While in most cases any type of infrared gun would be adequate, they are somewhat dependent on the emissivity of the service they are measuring. To get the most accurate results of service you are measuring needs to be calibrated to the gun you're using. A white concrete surface may lead to inaccurate results because a matte black surface has an emissivity of 1 and that of concrete is approximately 0.63.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 12-29-2016, 10:15 AM   #4
Rewards Points: 4,442
depends on your ' where ',,, we use 'em here in atl/hilton head,,, generally depend on o'nite temps more than anything else,,, i want 50f o'nite for a couple days,,, btw, we only use solvent-bas'd sealers - ' CSS ' is the main product
at least they're cheap - http://www.ebay.com/sch/i.html?_from...67706&_sacat=0
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 05:10 AM
ultimate concrete hardness Yodaman Concrete, Stone & Masonry 12 05-04-2015 07:47 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
