What To Use To Resurface Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-06-2012, 01:32 AM   #1
Hello everyone. Slowly renovating my home, and thanks to the internet it is going well. I have hit a snag though, as google and youtube can only take me so far.
As you can see from the photo - the floor is a little rough here. I want to clean up my basement floor - have it smooth and likely paint it. Can anyone tell me what the best thing to do here would be to get this smooth? There are so many concrete mixes available and I want one that would have the best adhesion, and would blend well to the existing. When it comes to the rest of the floor, it appears etching would be best (little bits of remaining paint on the surface)
thanks!
sdoerr2 is offline   Reply With Quote
Old 10-06-2012, 05:15 AM   #2
DIY staff
Rewards Points: 7,174
What caused the surface to fail like that?
Is the concrete soft?
I suggest that you chisel that open until you hit sound material--then prime with a liquid latex bond enhancer---then patch with a Vinyl concrete patching mix----if the edges need to be feather in really thin--use Ardex 'Feather Finish'
That product is a dark grey when dry---so painting (not staining) will be the best choice in that area.
Old 10-06-2012, 06:41 AM   #3
That area in question is what the furnace was sitting on top of - so I figure it is the "outline" of the original furnace.
Old 10-06-2012, 05:49 PM   #4
Rewards Points: 3,528
You need to break out that area,all the way down to the base and see what caused that depression,that's not normal for concrete to fail that way.
Canarywood1 is offline   Reply With Quote
Old 10-06-2012, 07:14 PM   #5
I don't think it really failed... it is solid as a rock.
Old 10-06-2012, 07:20 PM   #6
DIY staff
If it's good and solid--no pealing and flaking--then follow the directions that I laid out and you will be fine---
Old 10-07-2012, 10:20 AM   #7
Then why do you suppose it's broken away from the rest of the floor if it hasen't failed???
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
