What To Use For Filling Gaps Between Cement Surfaces? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-23-2012, 11:06 PM   #1
Rewards Points: 26
What to use for filling gaps between cement surfaces?
Hi all,
I need to fill some 30 year old gaps which are between some cement/concrete surfaces. Attached to this post is a picture. Water gets in to the gaps and makes it's way in to the crawlspace which increases moisture in the crawlspace.
Is there a certain type of filler to use? Would be great if the filler came in colors so i could try to make an attempt to match the original colors. Thanks for any tips.
withoutapaddle is online now   Reply With Quote
Old 08-25-2012, 07:27 AM   #2
Rewards Points: 236
i would use hydraulic cement. then restain the whole thing = looks like it needs it anyway.
Fix'n it is offline   Reply With Quote
Old 08-25-2012, 11:51 AM   #3
Rewards Points: 13,694
That slab and the stoop are going to move differantly so hydrolic cement is not going to work, it's just going to crack.
Foam backing rod and this http://www2.dupont.com/Caulk/en_US/p..._w_kevlar.html
Will fill the crack, but at some point it to is going to fail.
If that slab has sunk it's nothing but a funnel now feeding water to the crack, needs to be redone or jacked.
Far more likly your dealing with an unsealed crawl space, or there's cracks in the foundation.
concretemasonry (08-25-2012)
Old 08-25-2012, 06:18 PM   #4
Rewards Points: 3,622
You'll never seal that permanently,tear it out and replace it.
Canarywood1 is online now   Reply With Quote
Tags
cement gap filler
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 01:31 PM
How to fill gaps in cement backerboard? tripower Building & Construction 5 06-27-2009 03:31 PM
Cement board - corners...gaps? J187 Remodeling 2 04-01-2009 12:13 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
