What Are These Pipes? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-20-2014, 08:31 PM   #1
what are these pipes?
I'm planning on buying a very cheap house but there is one thing that bothers me. In the basement floor there is a square hole with pipes coming from the sides. The hole is filled with water. Is there a piece missing in between them?
This house was built in the 50's.
Junior_ is offline   Reply With Quote
Old 06-20-2014, 09:40 PM   #2
jschaben
Rewards Points: 502
Had something similar in a house I owned in upstate NY several years ago. Except mine was round and had a sump pump in it.
The pipes coming in from the sides (on mine) were perforated drain tubing that were run before the basement floor was poured. Those, coupled with the gravel bed for the floor, channeled water that got beneath the floor to the sump which was, in turn, pumped out of the house. The basement floor was also "floating", that is, not attached to the block basement walls. About a 1" gap all the way around. Not sure that is what you have,, more/better pictures may help.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
carpdad (06-21-2014)
Old 06-21-2014, 10:51 AM   #3
Rewards Points: 3,622
Yup, that's what's missing ,a sump pump.
Canarywood1 is offline   Reply With Quote
Old 06-23-2014, 04:04 AM   #4
Rewards Points: 4,640
unless i'm seeing things, there's 4 pipes,,, 3 look like terra cotta & the 4th appears to have some pvc on the end - possibly a ck valve,,, altho its not like any pro installed system i've ever seen, it appears you're missing the pump recommend zoeller's m 35 - eBay - usually $ 120 incl shipping various sellers
irc
ps - its rare a bsmt floor does NOT float,,, it only serves 1 purpose: something nicer than dirt to walk upon,,, that 1" slot was where the conc guy placed a screed rail,,, when removed, its called a ' slot drain '
Old 06-23-2014, 04:41 PM   #5
Thanks for all the info. I remember seeing a pump laying down on the floor somewhere that was not connected. Googling sump pumps.
Old 06-23-2014, 05:24 PM   #6
Rewards Points: 6,652
No need to google. Get in your car and go to your local Ace Hardware, Farm & Home Store, Lowe's, Home Depot. Take the picture with you and tell them you need a Sump pump.
They may ask you what horse power you will need. That will be your biggest problem. You are probably better in bringing in a plumber and have them run a camera first, to make sure that there are no problems in those lines. The plumber can then size the proper pump for your need.
Old 06-23-2014, 05:39 PM   #7
already gave you the information you need,,, bearing in mind apron/vest stores don't sell top of the line stuff & that includes tools & pumps,,, IF you need it day after tomorrow, buy it now on eBay & pay the extra shipping,,, you could also go to ferguson or grainger & pay retail
1/3 hp is the m53's rating @ 115v / 9.7a,,, @ 10', it'll pump 100gpm - that's 6,000 gal per hr ,,, its got a mechanical switch on stainless steel guides - NOT the ping-pong ball on a tether jury-rigg'd float switch,,, we do this work for a living & we use these pumps because they're the best
plumbers are NOT waterproofers - we regularly repair their work,,, about the only part i can agree on is the camera work,,, ask a plumber ' size ' a pump ? not in this lifetime then again, its YOUR house you'll do what you want if you're buying a cheap house, get a cheap pump as per previous posts
irc
The Following User Says Thank You to stadry For This Useful Post:
gregzoll (06-23-2014)
Old 06-23-2014, 06:51 PM   #8
itsreallyconc. Actually it depends on the Apron store. Our Menard's have guys that work in the trades, then work evenings or weekends there. Our Ace hardware has a really knowledgeable staff.
As for the pumps. They are all going to die some time. A lot depends on what is in the ground water, if they are left to run dry for a long period of time. Tools for the most. I would go with Kobalt. Half of my toolbox is Kolbalt hand tools.
Old 06-23-2014, 09:18 PM   #9
jschaben
Rewards Points: 502
I'm voting with calling the plumber. It's not clear in the picture just what you are to attach the pump to and where it is supposed to be pumping. A lot more questions here than "what goes in the hole?"
John Schaben
Old 06-24-2014, 03:43 AM   #10
this is f'n amazing,,, plumbers are NOT waterproofers,,, all a plumber needs to know is **** runs downhill, hot wtr's on the left, payday's on friday, & don' lick your fingers
countless times we've replaced plumbers work,,, its not that they couldn't do the work IF they knew how to do it,,, they're just not trained to do the work,,, look at any waterproofer's w/site,,, its ALL based on:
1 - water runs downhill;
2 - water takes the path of least resistance;
3 - water seeks its own level; &
4 - water rushes to fill a void [ try making a hole in a tub full of water ]
its only rocket science when you're building rockets,,, if you want to call a plumber, fine,,, how can a pump ' run dry for a long period of time ' that makes no sense to me but i'm only a dumb waterproofer maybe if i were a plumber, it might as far as ' A lot depends on what is in the ground water, it doesn't - its WATER, fergawdsake, not oil, molasses, or melted butter,,,, it MAY contain some because it doesn't appear to be a properly built sump - so put your pump on a riser ! nothing says ' successful pro ' more than seeing 1 working nites/weekends selling stuff in an apron/vest store - give me a break that's a positive ? ? ?
this is like talking to a boxes of rocks do ANY of you do this work for a living ? yes, pumps die - ALL things living & ALL things mechanical die,,, drainage systems are low-maintenance, NOT NO MAINTENANCE - that's why pro systems include cleanouts & filter fabric about the sump - not the pictured ' hole in the floor ' which looks like typical plumbers work to me.
nothing upsets people who know everything more than those who only THINK they know it all so do what your want ! i'm done contributing to this thread but i await further posts good luck nevertheless !
irc
jschaben (06-24-2014)
Old 06-24-2014, 08:10 AM   #11
Stonemason
stonecutter's Avatar
Rewards Points: 41
Originally Posted by itsreallyconc View Post
unless i'm seeing things, there's 4 pipes,,, 3 look like terra cotta & the 4th appears to have some pvc on the end - possibly a ck valve,,, altho its not like any pro installed system i've ever seen, it appears you're missing the pump recommend zoeller's m 35 - eBay - usually $ 120 incl shipping various sellers'
There are five terra cotta drain pipes and one sump line. That isn't a check valve, it's a threaded union.
irc
Where did you come up with those numbers for a 1/3 hp pump? That 6000 claim caught my eye....I have never seen a 1/3ho pump push past 2200 @ 10' head pressure. The model pump you listed is 2040 GPH @ 10'.
I'm sure a lot of plumbers would say that waterproofers are not plumbers.
stonecutter is offline   Reply With Quote
Old 06-24-2014, 09:48 AM   #12
never said it was a ck valve - only possibly
did i misread the chart ?
http://www.zoellerpumps.com/en-na/pr...technical-data
' waterproofers are not plumbers ' - we agree on that part
Old 06-24-2014, 10:03 AM   #13
Bill Kearney
Rewards Points: 1,174
And no doubt a lot of customers would say both were a huge pain in the butt.
I'd definitely seek a company doing waterproofing and basement work for this, well before I'd ask a plumber.
wkearney99 is offline   Reply With Quote
Old 06-24-2014, 10:32 AM   #14
Stonemason
Rewards Points: 41
Yeah, you did. The 34 @10' is for GPM. That translates into 2040 GPH.
Don't forget...waterproofers aren't plumbers.
Old 06-24-2014, 04:35 PM   #15
ratz - i did misread it i don't mind if plumbers take our work as long as its done correctly - that means NO pedestal pumps, too usually they'll just dig a hole thru the conc & stick in a pump, tho
irc
Insulating attic pipes thew60 Insulation 4 01-10-2014 02:23 PM
tree roots and orangeburg pipes xerxes2001 Plumbing 3 04-07-2012 08:26 PM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
