What Should I Use To Kill This Gap In Slab? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-25-2013, 08:42 PM   #16
Rewards Points: 6,652
Show a picture with a regular closet flange just dry fitted on there. Now of course the easier way would be to just get a slip joint to slip over that PVC, lube it up with Vaseline on the outside of the joint, and then put in the hydraulic cement.
After the cement has started to set, then you can pull the slip joint and let it finish setting until hardened.
Old 06-25-2013, 08:50 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 444
Originally Posted by Arsinek View Post
4 inch
Then use an inside flange like you showed us and pour the cement up to the pipe- forget the sill seal. I didn't mean to confuse you
Old 06-25-2013, 08:56 PM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Originally Posted by TheEplumber View Post
If the stub in the floor is 3" I would not use an inside flange- too restrictive.
It will be OK for 4" though.
If you choose to use an outside flange, wrap the pipe with 2 wraps of sill seal foam before applying the quickset, Then remove the wrap after it cures. This will give you a space around the pipe to receive the hub
Oh... 4"....I agree wholeheartedly with E.... Just use your ID flange and forget about wrapping it for an outside flange.
Best
EDIT: We're all saying the same thing... Sorry, we either x-posted or I missed some postings... it's cocktail hour here.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
TheEplumber (06-25-2013)
Old 06-26-2013, 01:03 PM   #19
747
registered
747's Avatar
Rewards Points: 534
Don't be intimidated by hydraulic cement. Go easy=take your time and don't get sloppy.
747 is offline   Reply With Quote
Old 06-27-2013, 09:31 AM   #20
Rewards Points: 274
If you accept to use an alfresco flange, blanket the aqueduct with 2 wraps of axle allowance cream fore applying the quickest, Then abolish the blanket afterwards it cures
alexjoe is offline   Reply With Quote
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Suggestion for new sidewalk slab flyboy_ont Landscaping & Lawn Care 7 05-22-2009 12:15 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
