What Should I Use To Kill This Gap In Slab? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-25-2013, 07:11 AM   #1
Rewards Points: 150
What should I use to kill this gap in slab?
My problem is this gap is making it so I cant screw down a toilet flange. So I was planning on filling in the space. What product should I use for this? Ill be wanting to drive screws into it.
Arsinek is offline   Reply With Quote
Old 06-25-2013, 07:34 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,786
Is that coming out of a concrete slab (SOG)?
I guess that it does not matter, but what was there before?
MTN REMODEL LLC is online now   Reply With Quote
Old 06-25-2013, 08:02 AM   #3
Rewards Points: 150
Ya, out of the slab. The old toilet flange wasnt screwed down, it came up with the old toilet when I pulled the old toilet off.
Old 06-25-2013, 08:21 AM   #4
To answer your question.... maybe a hydraulic cement... it expands just a little for good grab.... I don't think it would cause any problem with your pipe....
I might wait for others ideas though...
I might also try sinking a tapcon or redhead into the slab, with a washer on it, to try and anchor any cement plug.
Best
Old 06-25-2013, 09:27 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 904
Best
+1
I'll add- allow room for the flange hub if it goes over the pipe.
Old 06-25-2013, 05:46 PM   #6
Rewards Points: 150
This is the flange I bought...
Old 06-25-2013, 05:47 PM   #7
Rewards Points: 150
Best
So something like this?
Old 06-25-2013, 06:18 PM   #8
747
registered
747's Avatar
Rewards Points: 534
yes... go easy with the hydraulic cement. It expands when it dries. It also sets up rather fast.
747 is offline   Reply With Quote
Old 06-25-2013, 06:26 PM   #9
Plumber
Rewards Points: 904
If the stub in the floor is 3" I would not use an inside flange- too restrictive.
It will be OK for 4" though.
If you choose to use an outside flange, wrap the pipe with 2 wraps of sill seal foam before applying the quickset, Then remove the wrap after it cures. This will give you a space around the pipe to receive the hub
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (06-26-2013)
Old 06-25-2013, 07:06 PM   #10
Rewards Points: 150
What about this stuff?
Old 06-25-2013, 07:22 PM   #11
You know.... I don't know how "you go easy" with hydralic cement. Seems to me you either fill the hole or you don't.
The expansion is pretty slight.... and I THINK you'd be fine. But you had your toilet in there fine with no setting screws, so maybe it's not that important to get that tight a bond (not like a hand railing balluster into a slab for instance).
Try the vinyl patch if you're uncomfortable with the hydraulic. And don't forget to shim the toilet level and throw a nice bead of caulk around it's base (leave several inches behind un-caulked in case you had a wax seal leak) I think you'll be fine that way too.
Plus if the vinyl did ever fail, you could dig it out and then use hydraulic.
Just my thoughts
Best
EDIT: As a comment, generally the vinyl patch is not a structural cement... and I guess my thought would be that you don't really need a heavy duty structural application.
Old 06-25-2013, 07:25 PM   #12
Rewards Points: 150
Where do I get this sill seal foam? Im assuming you can pull it out after the cement dries?
Old 06-25-2013, 07:35 PM   #13
It would be in the concrete isle of a big box.... only problem is I think the smallest roll is maybe 50 feet.
Take a look at it, and you'll understand, you can probably find some packing material or carpet padding or something else.Or put your flange on and then pack around it....assuming you have room to do so.
Old 06-25-2013, 07:38 PM   #14
Is that drain pipe 3 or 4"
Old 06-25-2013, 07:39 PM   #15
Rewards Points: 150
4 inch
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Suggestion for new sidewalk slab flyboy_ont Landscaping & Lawn Care 7 05-22-2009 11:15 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
