What Is Happening To My House? Mold? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-12-2012, 05:40 PM   #1
I love my new front yard!
Telfair's Avatar
Rewards Points: 158
What is happening to my house? Mold?
1've seen this out front & thought it was the sprinklers maybe, Yet I adjusted the sprinklers & they don't spray the wall..
& now I've noticed that its also happening inside my entry to my basement.
Telfair is offline   Reply With Quote
Old 11-12-2012, 05:45 PM   #2
Rewards Points: 14,312
http://www.basementquestions.com/efflorescenc.php
Old 11-12-2012, 07:29 PM   #3
Telfair's Avatar
Rewards Points: 158
Originally Posted by joecaption View Post
Thanks for the link, yet now I have to figure out the source of moisture?
FYI: The house is in the Los Angeles area & was built in 1929
Old 11-12-2012, 07:34 PM   #4
Just a guess because I'm not there to see it.
But I'd bet if you dug down toward the footing your going to find the block was never sealed below grade so the waters wicking up the wall.
Notice it's all along the lower areas.
Old 11-12-2012, 07:58 PM   #5
Telfair's Avatar
Rewards Points: 158
So what do I do?
Old 11-12-2012, 08:06 PM   #6
Busy DIYer
picflight's Avatar
Rewards Points: 150
Seal the block I would guess.
Sent from my iPhone using DIY Forum
picflight is offline   Reply With Quote
Old 11-12-2012, 09:14 PM   #7
Rewards Points: 29
The wall is definitely taking in water.
Check your downspouts make sure they are extended out from the house.
Check your sprinkler system for an inground leak
Check drainage and slope around the house.
MarkusAIC is offline   Reply With Quote
Old 08-29-2013, 07:48 PM   #8
Telfair's Avatar
Rewards Points: 158
Ok so I'm finally gonna fix this, gonna try the muriatic acid 1st as the link suggest & then use this high quality stuff my new home handy man recommends over the bargin stuff I have in my shed & he says it should last at least 5 years but after this starts, the walls are basically infected & its hard to make it completely stop, but I suppose as he says the house will not fall down or anything with this...?
I forgot to show him the basement, but will have him fix that as well while he's working on the front.
& yes he plans to repair the side under the house as well.
Old 09-02-2013, 04:39 AM   #9
Rewards Points: 4,806
if i were you & had no idea what was going on, i'd think about asking either a pro restoration specialist OR pe to comment,,, a ' new home handy man ' & a bunch of guys on the i-net would hardly be my final resource but its YOUR home,,, we don't even know IF you've accurately described the issue,,, but this is just my opinion,,, there's a cure for ignorance but stupid's often fatal
IF your cmu's are under acid attack, the house WILL fall down,,, doesn't it make sense if you remove anything supporting a load ( your house ), the load obeys the laws of gravity ? all houses fall down eventually,,, the questions should be ' when ? ' & ' how do i maintain what i have ? '
' I forgot to show him the basement, but will have him fix that as well while he's working on the front...& yes he plans to repair the side under the house as well. ' i'm not convinced that's the right course of action but, after all, it IS your home
Old 09-02-2013, 12:57 PM   #10
Telfair's Avatar
Rewards Points: 158
Originally Posted by itsreallyconc View Post
[FONT=Comic Sans MS][SIZE=3]if i were you & had no idea what was going on, i'd think about asking either a pro restoration specialist OR pe to comment
What is a PE & or where do I find a pro-restoration specialist?
Never even heard of that?
Where in Los Angeles would I find one that wont try to sell me his farm?
Old 09-03-2013, 05:46 AM   #11
anyone else want to take this 1 ? i'd suggest you invest some time reading previous threads on similar subjects - water in basement, leaking basements, sump pumps, etc.
' PE ' = professional engineer,,, as for the other question ( ' where do I find a pro-restoration specialist ? ' ), try googling waterproofing or waterproofing contractors - even in la i'm sure you'll fine at least a couple.
as for finding 1 who ' wont try to sell me his farm ', let's remember no one works for free - even you,,, ' free inspections ' are the trade's nickname for a sales pitch based on the inspector's ( salesman ) knowledge, training, & experience,,, IF you knew the problem & its solution, you could invite qualified contractors to bid on your work according to your specifications,,, you don't so why not take this opportunity to learn from those you call,,, you'll also find contacts on craig's & angie's list along w/qualified pro's listed on the national association of waterproofing & structural repair contractors website
the intent of this forum ( imo ) is to teach others HOW to fish, NOT feed them,,, good luck !
Old 09-03-2013, 03:46 PM   #12
Telfair's Avatar
Rewards Points: 158
Well, now that you have me paranoid I've looked on Yellowpages.com & found some & at this point called these guys & they will come out soon to do their "Free" inspection?
http://www.yellowpages.com/north-hol...?lid=466592602
Maybe I'll get a few free inspections from various companies & see if they all say the same?
Old 09-03-2013, 04:20 PM   #13
Telfair's Avatar
Rewards Points: 158
To be honest after calling 3 places I'm starting to think these are all just handy men?
One guy seems to only be wanting to do a free estimate via text pictures & now just replied saying to come look it over is $150 & then says $1,500.00 & he has not even come out to see it yet! WTF?!?!
Old 09-03-2013, 05:15 PM   #14
GBrackins's Avatar
Rewards Points: 2,108
some charge for "inspections" and extra for recommendations of what needs to be done. After all they are in business to make money and time is money. I give free "estimates" in my profession (written proposal for service) but I'm not going to tell you everything until you hire me.
call your doctor and ask him to fax over a prescription to your pharmacy because you have a sore throat. you'll typically have to pay ($$) his office a visit before you get the script
most contractors I know prefer to see first hand the site before providing any estimates or proposals. besides, how can you know what needs to be done until you figure out what's the problem.
patience, patience, patience, goes a long way ....... good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-03-2013, 05:34 PM   #15
Telfair's Avatar
Rewards Points: 158
& thats my point!
How can he claim the repair is $1,500.00 without ever seeing it in person?!?!?!?!
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 03:57 PM
Mold on roof sheathing!!! DIYMILF Roofing/Siding 10 08-14-2011 09:11 PM
New House in NE Ohio, Mold Worries mikeylikesit580 General DIY Discussions 6 11-19-2010 12:25 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
