Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-06-2012, 03:23 PM   #1
What did I do wrong?!?
I am in the process of rocking my fireplace and have a problem. My contractor told me I could use cement board and mortar hearth and stone directly to it (without using a scratch coat and wire mesh). I have a done 1 fireplace in my lifetime using the scractch coat method (over tar paper and sheetrock) and everything turned out great. Last night I got all of my cement board up and started with my hearth stone. I buttered the hearth stone with approx 1/2" of type s mortar and laid it directly on the cement board ( I wiggled it in there and put some pressure on it). Well I came back this morning and was able to pick up every piece of stone I laid . The mortar barely adhered to the stone or cement board (I was able to pry it off pretty easily)> Should I be using type N mortar or do I need to go the scratch coat direction. Thanks for any information you can lend to me.
danreg99 is offline   Reply With Quote
Old 03-06-2012, 03:38 PM   #2
Ironlight's Avatar
I'm going to suggest that if you put it down last night and then tried prying it up this morning, that it came up for the simple reason that it had not yet completely set. I would not have touched it for at least another 24 hours.
As to the suitability of cement board for the backing without expanded metal and a scratch coat, I don't have the expertise to comment on that. But regardless of it's long term durability, the cement should bond adequately to the cement board.
Ironlight is offline   Reply With Quote
Old 03-06-2012, 03:53 PM   #3
Actually I put it down at about 6 pm and lifted it at lunch time today. Wouldn't there be some adhesion by then? Cement board was basically clean of any mortar.
Old 03-06-2012, 03:59 PM   #4
joed's Avatar
How was the mortar? Hard? Soft? Crumbly?
Could be the board and stones were too dry and sucked all the moisture out of your mortar.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-06-2012, 04:06 PM   #5
When I mixed the mortar last night I mixed it to the consistency of mashed potatoes. When I pulled it off the rocks today it broke off into 2 " chunks and kind of reminded me of cookie dough.. Should I mix more water into the mortar? Or should I put a scratch coat with type s over the cement board ? I have read some other forums and they suggest wetting the cement board with a sponge. Do you think that would work?
Old 03-07-2012, 09:06 AM   #6
Concrete & Masonry
Are you using a pre-mix mortar? If so I'd suggest adding a few ounces of bonding agent to each bag and maybe even a little additional lime as well. And you definately want to get the backer damp first.
jomama45 is offline   Reply With Quote
Old 03-07-2012, 09:23 AM   #7
Cement board is usually VERY dry. I usually mist it a few times using a spray bottle before tiling. I also spray each area again before I spread more mortar.
wewantutopia is offline   Reply With Quote
Old 03-07-2012, 10:03 AM   #8
joed's Avatar
The other question is are you premixed mortar or mortar cement that needs to be mixed with sand? What was your mix ratio if using mortar cement?
Old 03-09-2012, 11:05 AM   #9
Thanks for all the info guys. I ended up misting the cement board and using thinset on the rocks and that stuff really holds! The idea about the dry cement board was spot on!
The Following User Says Thank You to danreg99 For This Useful Post:
jomama45 (03-10-2012)
IS this wrong? Romex connector? JeepNick Electrical 27 02-29-2012 11:30 AM
Used the wrong nails. ndmeier Remodeling 10 02-18-2012 11:42 PM
Staining project - Did I do something wrong - Need help. family_man Painting 4 11-03-2011 02:10 AM
2 handle shower wrong direction Lisa C Plumbing 7 07-24-2011 10:28 AM
what am I doing wrong? jdhar Painting 7 06-20-2009 12:35 AM
