What Is Causing My Slab To Become Powdery - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-04-2013, 11:51 PM   #1
Rewards Points: 83
What is causing my slab to become powdery
Anyone have seen this before? We once has an ant problem.
It's right below the t1-11 wood panel (exterior)
What is causing my slab to become powdery-image-3259202323.jpg   What is causing my slab to become powdery-image-1770695640.jpg
hawaiiboy is offline   Reply With Quote
Old 02-05-2013, 05:36 PM   #2
Rewards Points: 4,534
still do have an ant problem as that is the result of the dreaded antus concretus digesterous ( concrete eating ant larvae ) as they transition to adulthood,,, IF they get large enough AND hungry enough, your house will soon fall down
actually its efflorescence which is causing the coating to fall off,,, check for moisture behind the wall
Old 02-05-2013, 06:09 PM   #3
Rewards Points: 13,260
Sure it's not just aluminum that was used as a termite shield that's falling apart because it came in contact with the pressure treated foundation plate?
Correcting Water Intrusion Around My Slab PeteW Building & Construction 0 08-26-2011 11:49 AM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Slab under slab in 100yr old house Master Brian Building & Construction 2 08-23-2010 08:35 AM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Sewer leak below slab. Debris in sand. martin52 Plumbing 2 10-20-2006 09:43 AM
