What Can I Use For Spacer Around Pvc Pipe For Cement Repair? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-23-2013, 04:01 PM   #1
Rewards Points: 150
What can I use for spacer around pvc pipe for cement repair?
Bascially, this is exactly what Im doing....
2 problems, I dont know where to get the "coupler" they are using, it goes inside the pipe instead of outside and no where around here sells the Oatley foam closet spacer I think theyre using.
I could probably figure something out for the coupler but I dont know what to do about the spacer. Anyone know what I could do for that? Would any foam sheeting work?
Arsinek is offline   Reply With Quote
Old 06-23-2013, 07:23 PM   #2
CitadelBlue's Avatar
Rewards Points: 97
I've seen what was in the video at Home Depot and Lowes. But Check out this product. Its available by mail. I used it to repair an unlevel, broken flange in my master bath.
http://set-rite.com/
CitadelBlue is offline   Reply With Quote
Old 06-23-2013, 08:06 PM   #3
Rewards Points: 150
Well, Home Depot sells it but not in my area for some reason. I just went a head and ordered a couple on their website.
Old 06-24-2013, 06:14 AM   #4
Rewards Points: 4,584
on occasion we'll use packing foam,,, got it @ the ups store
Old 06-26-2013, 08:22 AM   #5
Rewards Points: 97
You will also need 2 regular wax seals
Old 06-26-2013, 06:15 PM   #6
Rewards Points: 150
2? Why 2?
Old 06-26-2013, 07:31 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 564
The coupling is a standard fitting. If you look closely at it in the video- they sanded it to fit into the pipe.
IMO- you don't need the wrap if you put the flange inside the pipe stub.
An alternative method is to buy an expansion test plug- put it in the pipe.
Then pour your concrete up to the pipe- remove the plug and set your inside flange.
If the pipe is too low-use stiff card stock for a wrap
Old 06-27-2013, 02:26 PM   #8
Rewards Points: 97
2? Why 2?
check out the video at the web site .....http://set-rite.com/
One is used as it was suppose to (toilet to flange); the other (old flange to new flange) ...
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Repair shutoffs on galvanized pipe from 1950s bryanp22 Plumbing 3 03-26-2012 12:36 PM
Leak repair of Compressor (pipe fitting) redavalanche Tools 3 12-23-2010 07:37 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
