What Is The Best Way To Remove Post In Concrete?? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-20-2014, 04:50 PM   #1
Rewards Points: 672
What is the best way to remove post in concrete??
I have two footings in concrete that I need to remove. They are approximately 17in deep by 17in across. Any suggestions on an efficient way to remove them short of getting a jackhammer? They are in clay soil.
Thanks for any suggestions.
What is the best way to remove post in concrete??-post.jpg   What is the best way to remove post in concrete??-post1.jpg
kennykenny is offline   Reply With Quote
Old 01-20-2014, 05:25 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... They look deep enough to just leave 'em there, bury 'em,....
If ya really want 'em out, Keep Diggin',...
once loose,... lever it, roll it outa the hole,...
Old 01-20-2014, 05:40 PM   #3
Rewards Points: 672
I need to remove the concrete because I need to replace the posts.
Old 01-20-2014, 05:52 PM   #4
Rewards Points: 13,732
Drill a pilot hole in the middle of the post and screw in a 1/2" X 6" eye bolt.
Use a 2 X 4 standing on end and a piece of chain or strong rope and two people to lift it up out of the hole.
CENTERLINE MV (01-22-2014)
Old 01-20-2014, 05:59 PM   #5
Rewards Points: 1,278
Can everyone read all the text now ?
QUOTE:I have two footings in concrete that I need to remove. They are approximately 17in deep by 17in across. Any suggestions on an efficient way to remove them short of getting a jackhammer? They are in clay soil.
Old 01-20-2014, 06:05 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Dig around it until you can get a chain around it, hook the chain to your truck. Use a tire that is on the rim and stand it up as close to the hole as you can and lay the chain over the tire, you want it so the tire will roll. When pulling with your truck it will pull the stuff in the hole straight up and out.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
CENTERLINE MV (01-22-2014), oh'mike (01-20-2014)
Old 01-20-2014, 08:50 PM   #7
Rewards Points: 236
an engine hoist will lift that right out.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
BigJim (01-20-2014)
Old 01-21-2014, 06:19 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,706
Get an anchor in it and hoist it out by multiple person or by hoist/wench.
Old 01-21-2014, 07:44 AM   #9
Rewards Points: 4,656
attach gold teeth then wait,,, some gangbanger'll come by soon & steal 'em,,, sledgehammer & point ? crowbar & 2x4 ? ea post roughly weighs 100# so how hard is that ?
ps - like the tire idea ( fulcrum/lever ) - have to remember that 1
Old 01-22-2014, 06:26 PM   #10
Rewards Points: 3,628
One of these will work also.
http://www.harborfreight.com/8000-lb...uller-543.html
Canarywood1 is offline   Reply With Quote
Old 01-22-2014, 07:58 PM   #11
Solutions (handyman)
Rewards Points: 364
post removal
If you can put a chain around it , use a jack-all ... if it isn't in too deep,, this should work.If not, as was mentioned, keep digging.
Mark Harvey is offline   Reply With Quote
Replace post between roof and concrete patio. clintonb Building & Construction 4 05-27-2013 06:10 PM
Remove old lawn first or concrete first? jimleahman Landscaping & Lawn Care 6 04-26-2012 03:56 AM
How to repair deck post on a concrete footer? abchow1 Building & Construction 2 09-19-2011 03:05 AM
Steel post in concrete alexj212 Building & Construction 4 11-24-2010 01:19 PM
mounting 4x4 wood post to concrete porch pshinaults Building & Construction 1 05-27-2010 02:53 PM
