-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   What is the best way to remove post in concrete?? (http://www.diychatroom.com/f105/what-best-way-remove-post-concrete-194393/)
kennykenny 01-20-2014 05:50 PM
2 Attachment(s)
I have two footings in concrete that I need to remove. They are approximately 17in deep by 17in across. Any suggestions on an efficient way to remove them short of getting a jackhammer? They are in clay soil.
Thanks for any suggestions.
Bondo 01-20-2014 06:25 PM
Ayuh,... They look deep enough to just leave 'em there, bury 'em,....
If ya really want 'em out, Keep Diggin',...
once loose,... lever it, roll it outa the hole,...
kennykenny 01-20-2014 06:40 PM
I need to remove the concrete because I need to replace the posts.
joecaption 01-20-2014 06:52 PM
Drill a pilot hole in the middle of the post and screw in a 1/2" X 6" eye bolt.
Use a 2 X 4 standing on end and a piece of chain or strong rope and two people to lift it up out of the hole.
SeniorSitizen 01-20-2014 06:59 PM
Can everyone read all the text now ?
QUOTE:I have two footings in concrete that I need to remove. They are approximately 17in deep by 17in across. Any suggestions on an efficient way to remove them short of getting a jackhammer? They are in clay soil.
BigJim 01-20-2014 07:05 PM
Dig around it until you can get a chain around it, hook the chain to your truck. Use a tire that is on the rim and stand it up as close to the hole as you can and lay the chain over the tire, you want it so the tire will roll. When pulling with your truck it will pull the stuff in the hole straight up and out.
Fix'n it 01-20-2014 09:50 PM
an engine hoist will lift that right out.
Windows on Wash 01-21-2014 07:19 AM
+1
Get an anchor in it and hoist it out by multiple person or by hoist/wench.
stadry 01-21-2014 08:44 AM
attach gold teeth then wait,,, some gangbanger'll come by soon & steal 'em,,, sledgehammer & point ? crowbar & 2x4 ? ea post roughly weighs 100# so how hard is that ?
ps - like the tire idea ( fulcrum/lever ) - have to remember that 1
Canarywood1 01-22-2014 07:26 PM
One of these will work also.
http://www.harborfreight.com/8000-lb...uller-543.html
Mark Harvey 01-22-2014 08:58 PM
post removal
If you can put a chain around it , use a jack-all ... if it isn't in too deep,, this should work.If not, as was mentioned, keep digging.
