What Is Best For This ? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-17-2014, 07:54 AM   #1
What is best for this ?
I was drilling through a column and a wall tile.had problem with both
but for the tile i first punched a small point then i drill through that point so the drill wont slip.
But for the column i am using a Bosch hammer drill (trying to fit a fastener)
and pretty tough job it was..and both things really took a long time ..
any tips to get it done fast..
tonysteve66 is offline   Reply With Quote
Old 01-17-2014, 08:14 AM   #2
Rewards Points: 14,312
What size hole? For a larger hole drill a smaller one first. Let the drill do the work. If you push to hard it can slow down the hammering effect. Back it out once in a while to clear the dust.
Sure the drill was sharp? They wear out pretty fast.
tonysteve66 (01-23-2014)
Old 01-18-2014, 08:59 AM   #3
Rewards Points: 240
what is the column made of ?
Fix'n it is offline   Reply With Quote
Old 01-23-2014, 04:50 AM   #4
4 inch and length is approx 7 inchs.. and when i did that.. me not fully used drill machine also used hammer
Old 01-23-2014, 04:58 AM   #5
Must be missing something.
"4 inch and length is approx. 7 inchs"
What exactly is it your trying to achieve?
Old 01-23-2014, 05:54 AM   #6
Rewards Points: 4,806
column's what - steel, black iron, wood, concrete, ( ? ) or are we supposed to guess ? maybe you need a 550rpm 1/2" drill & steel bit(s) OR diamond bits for tile,,, hard to see your house from our house can't imagine why 1 would use a hammer drill unless its conc,,, NEVER use a hammer drill on tile as it shatters tiles
typically we like to let power tools do their work,,, usually easier IF we pick the right tools
