Wet Crawlspace Fix - Concrete, Stone & Masonry - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-08-2013, 03:50 PM   #31
I'll try to take some tomorrow. As I said before, those original photos are of a different property (not mine).
EdTDuck is offline   Reply With Quote
Old 08-13-2013, 02:38 PM   #32
Alright. Sorry for the delay. Had a main sewer line leak into my crawlspace over the weekend, so that took priority (sigh, it never ends...).
So, here are photos of my property showing the affected area (it's an extension with a separate crawlspace.
Photo 1 shows the terraced garden and the affected part of the house (2 floors). There is just loose paving on the floor, which should be easy to lift up if I need a trench or re-grading here.
Photo 2 shows another angle of the same area in photo 1.
Photo 3 shows the side pathway. The crawlspace entrance leads to the affected area. The saltillo tile is on a concrete substrate. The grading is not so good and water tends to puddle in low points as you can see from the efflorescence. I've been told drains can be put in by cutting a strip through the concrete.
Thanks for any advice you can give!
Wet crawlspace fix-photo1.jpg   Wet crawlspace fix-photo2.jpg   Wet crawlspace fix-photo3.jpg
Dirt floor conditioned crawlspace with horizontal 80% furnace, and mold remediation WillK General DIY Discussions 0 04-29-2012 10:20 PM
Ventilated or Unventilated Crawlspace? Thunder Chicken Building & Construction 12 01-09-2012 09:08 PM
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 01:35 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
