Wet Concrete Slab Issue - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-29-2013, 10:21 AM   #1
Wet concrete slab issue
I Sure hope you folks can help me out. My wife and I just had a very large screened in porch added to the back of our house. It started with a 10x10 slab that was put in when the builder built the house. Or contractor added a new slab next to it and two feet in front of it. We have a lagoon in our back yard and as such have a fairly high water table.
Now the issue, the original 10x10 slab gets soaking wet every time it rains, while the new slab remains bone dry. My thought is that the builder did not put down a vapor barrier, and it's wicking water from the ground after a rain. I know the contractor who built the room did install a thick barrier (plastic) because is we him do it. We did not notice this before as the original slab was open and had no roof. Now that it has a roof it's become very obvious.
Is there anyway for me to keep my original pad dry after a rain?? Any kind of product I can add to the top??
Thanks in advance !!
Gsragtop is offline   Reply With Quote
Old 12-29-2013, 07:53 PM   #2
Rewards Points: 13,300
We can not see what your seeing without a picture.
Old 12-29-2013, 08:12 PM   #3
Rewards Points: 3,418
You 've answered your own question,and there's nothing you can apply that I know of that will keep the water from wicking on that old slab.
Canarywood1 is offline   Reply With Quote
Old 12-29-2013, 10:44 PM   #4
Msradell's Avatar
Rewards Points: 128
Like Canary said, you've already identified the problem which is a start. However, there's not really any way to add anything now to help the problem. The best and probably only real solution will be to move the old pad, install vapor barrier and repour it.
Are you sure the water is coming from underneath and is not just moisture that's condensing on the cooler surface from high humidity in the air?
Msradell is offline   Reply With Quote
Old 12-31-2013, 12:11 AM   #5
Rewards Points: 626
Well the OP say that there is a roof over it and the original slab is in the middle so yes that would be a great indicator that no vapor barrier was put down. the easiest way to fix it is rent a jack hammer and rip it out put in a 6mil min poly barrier and re pour the pad.
Nailbags is offline   Reply With Quote
Old 12-31-2013, 07:36 AM   #6
Rewards Points: 712
If a vapor barrier being omitted when the 10x10 was poured is causing the problem it would have been wet 24/7 before the screened in structure was built.
Old 12-31-2013, 10:53 AM   #7
Someone asked if it could be condensation rather then water from below.. That's a good question and one I did not really think about.. How can I tell?? Is it possible for me to get condensation on the old pad and none on the new??
Ripping up the old pad to repour it is not an option as part of it is under the structure of the enclosure.
I guess its something I will have to live with at this point.. I was hoping there was a waterproof treatment I could put in top that would keep the water from surfacing, but I guess there is not.
Old 12-31-2013, 12:55 PM   #8
Rewards Points: 582
Try taping some polythene to the floor. If the moisture is under it's probably rising damp, if on top condensation.
stuart45 is offline   Reply With Quote
Old 12-31-2013, 11:16 PM   #9
Msradell's Avatar
Rewards Points: 128
You beat me to it. Just make sure that the polyethylene is in complete contact with the floor so it's the same temperature on both sides.
Old 01-01-2014, 06:14 AM   #10
Rewards Points: 4,534
on occasion we have retrofitted vapor barriers under existing industrial conc floors for clients w/deep pockets,,, not sure it makes $ sense for you but its possible,,, will monitor the thread
currently in fl - 2' wtr table - no vapor barriers - no wicking - no wet slabs
Old 01-01-2014, 12:33 PM   #11
Rewards Points: 712
Sure it's possible. All that's needed is a difference in surface temperature of the two slabs. With as little as one degree difference it is very possible.
Old 01-01-2014, 12:56 PM   #12
Rewards Points: 334
You could try digging a trench around the slabs and putting stones and plastic drain tile in there.
tribe_fan is offline   Reply With Quote
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 03:17 PM
