Wet Basement - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-20-2012, 07:42 AM   #1
wet basement
I have small cracks in my basement brick wall and I need to seal those and also what is the best soil or gravel to use when I make a slope on the outside of the house for water to drain?
kim123456 is offline   Reply With Quote
Old 06-20-2012, 07:43 AM   #2
Rewards Points: 14,300
Is it really brick or is it block, big differants?
Old 06-27-2012, 10:05 AM   #3
Helpful information for your basement crack issue
If the cracks are in the brick itself, you can use a colored epoxy. This can be purchased from hardware stores or mason supply stores. It is not recommended to put gravel around the outside of your house, however. Use regular topsoil and pack it tight with a slope away from the house.
Ameri-Dry Guy is offline   Reply With Quote
Basement sewer smell jturk1000 Plumbing 1 09-20-2011 12:59 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
