Wavy Slab Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-07-2012, 01:03 AM   #1
Wavy slab floor
So I'm looking at a property that I may want to purchase, a slab-on-grade brick house in Cleveland, Ohio, built in the 1950s, and the floors are wavy where they meet the slab. Not by a ton, but fairly noticably so. Normally this would make me run away, but there is absolutely no separation in the bricks (or any evidence of tuckpointing to hide separation; those suckers are in the same place they were when Eisenhower was president...), nor cracks in the walls/ceilings, and the yard and sidewalk out front share the same kind of wavyness. This wasn't cited on the muni POS, so I'm wondering if this sounds like a broken slab or just a wavy grade. Any info or advice is appreciated, thanks!
unclepaulie216 is offline   Reply With Quote
Old 12-07-2012, 04:52 AM   #2
Rewards Points: 4,656
when you can describe the color ' blue ' over a phone, we'll be able to actually SEE a picture of what you post we have luck flattening floors prior to diamond polishing but your issue sounds different
i know i'm the only 1 who can't translate the ' muni POS ' could you also translate that for me ' POS ' does sound familiar to me but not in this circumstance then again, perhaps my guess IS correct & we just both think similarly regarding govt & its employees
Old 12-07-2012, 06:41 AM   #3
Rewards Points: 13,732
Could be anyone of these.
http://acronyms.thefreedictionary.com/POS
I'll make a guess the poster is from France or Canada and it's this one.
Plan d'Occupation des Sols
Mid span bridging lylsutherland Building & Construction 2 10-29-2012 11:10 PM
Building room with floor joists over slab. Moisture? FogNoggin Building & Construction 0 01-29-2011 10:00 AM
Radiant Floor Heat question - suspended slab quadradeuce HVAC 3 12-27-2010 09:18 PM
radiant floor heat over slab subfloor Terry68 Flooring 9 06-13-2010 05:58 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
