WaterProofing Onolith Foundation Basement - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-21-2013, 04:38 PM   #1
WaterProofing onolith foundation basement
Situation: Im finishing my basement in my 1956 cape in NJ. The basement has gotten seepage where the floor meets the concrete block. Not a lot, moisture is only visable after major storms but as far as I am concerned any amount of water will lead to mold.
We have a low water table, therefore the seepage is from rain or ground run off water.
I attempted to have an interior French drain installed; however they discovered I have a monolithic footing and the poured concrete is approx. 3’ deep within 2-3' off the concrete block.
When looking at the floor the concrete block sits a few inches into the slab.
All gutters are cleaned. Grade is pitched away from the house.
Basement will be finished with foam board insullation, metal studs, drywall and engineered wood flooring with underlayment.
Are there alternative options for a interior French drain OTHER then an exterior drainage system? Or any other ideas to solve this water issue??
Thank you in advance
Stcrosby is offline   Reply With Quote
Old 07-21-2013, 05:45 PM   #2
Rewards Points: 13,446
Can you post some pictures of the outside of the house?
Old 07-21-2013, 06:45 PM   #3
Old 07-21-2013, 07:15 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,402
Crosby... I'm actually not sure what a mono-lith foundation is,,, obviously not a mono-pour from your description... so you may get better suggestions, more knowledgeable from others.
However, in a sub basement (75%) below grade in my own personal home, on a stemwall/slab assembly, I had minor leakage under heavy snow melt conditions. With 6 ft under ground, even with decent slope outside... not too surprizing.
I was able to completely resolve it with:
1) Packing hydraulic cement at my stem to slab cold joint (maybe a 1" concave caulk-like joint) and
2) UG Water block on the walls... I used the oil base, and applied it well, making sure it penetrated all pores
You might try it... but test it before covering it up...
Obviously, shedding water, giving it a path of less resistance, is better than trying to block it... but sometimes the only option is a combination
Best
Peter
MTN REMODEL LLC is offline   Reply With Quote
Old 07-21-2013, 08:55 PM   #5
Sorry, I used the wrong terminology. I have a mono pour footing.
I was thinking about something like this but there is no visible joint gap, does that matter??
I feel this may work temporarily but Id rather fix the problem at the source. But thanks for the advice.
Best
Peter
Again thanks for your experience
Old 07-22-2013, 07:07 AM   #6
ccarlisle's Avatar
You might want to reconsider metal studs down there; look into blue wood...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 07-22-2013, 07:13 AM   #7
Crosby..... Could not agree with you more
Old 07-22-2013, 10:34 AM   #8
Please explain. My thoughts are that even pt wood will eventually become a food source for mold. Metal may corrode over time but these studs are not structural therefore id rather the lesser of two evils.
I'd like to hear what other think??
Thanks,
Old 07-22-2013, 11:54 AM   #9
ccarlisle's Avatar
Blue boards (for studding) repels moulds - that's why they make them, specifically for basements...
I should be more specific: 'Bluwood' is the trade name up here, so I imagine it's the same in the US. But maybe not...
Old 07-22-2013, 01:40 PM   #10
You are correct, we do not see a lot of them down here but I am familiar with them. I'm still curious why you prefer bluwood over metal??
Old 07-23-2013, 07:09 PM   #11
Rewards Points: 4,578
ooops - didn't see this thread so responded to the top posting,,, we used it often when we had our biz in nj,,, IF the lower block courses are grout-filled, you need to move the drainage holes up where you can drain the water,,, add fiber-reinforced f/g panels* & finish it off
monopour - unipour - turned-down edge --- they're all the same,,, good luck !
* - rest room walls in gsp & njtpke
Old 07-23-2013, 08:53 PM   #12
Please explain?? I understand about drilling where the water is but the panels???
Old 07-23-2013, 10:05 PM   #13
all these cove systems have to stand off the wall a bit so any leaking water can run down the wall, behind the cove system, & drain away,,, IF your drain holes are 2 courses above the floor, would you have them exposed or covered ?,,, hence the f/g panels,,, 1 can always sheetrock above the panels at 4' or whatever elevation you choose
is mid-atlantic still in biz ? we started subbing from them as an installation crew then started our own,,, call them for REALLY CREATIVE PRICING :-)
Old 07-26-2013, 08:14 PM   #14
Yes I believe they are but they get very poor reviews from the BBB and customer reviews.
Old 07-26-2013, 09:21 PM   #15
so what's new ? they did 20yrs ago but they're still truckin'
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
decision point in my exterior basement waterproofing project c2g Building & Construction 7 03-02-2011 05:41 PM
Basement concrete foundation wall insulation question pameyer Building & Construction 0 01-28-2011 12:05 PM
Basement addition foundation questions hoggin03 Building & Construction 7 05-29-2009 07:28 AM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 07:54 AM
