Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-02-2012, 09:46 PM   #1
Waterproofing a concrete box?
If you wanted to waterproof a concrete box, could you just cover it with fiberglass resin? It would take a lot of resin, but I like that resin seems to adhear to itself, where epoxy tends to de-laminate.
What about using a pond liner?
tibberous is offline   Reply With Quote
Old 10-02-2012, 09:53 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
blue skin
woodworkbykirk is offline   Reply With Quote
Old 10-03-2012, 12:25 PM   #3
Hydroban
pwgsx is offline   Reply With Quote
Old 10-03-2012, 05:10 PM   #4
GBrackins's Avatar
what is the purpose and use of the waterproof concrete box? will there be any openings in the box? will it be installed above ground or underground? need more information ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-03-2012, 05:14 PM   #5
sdsester's Avatar
You can buy nursery/plant liners, with or without holes, in just about any size and shape you can imagine. They are sold in different mil thicknesses though so be careful not to get one too flimsy.
sdsester is online now   Reply With Quote
Old 10-03-2012, 07:07 PM   #6
Is this, by chance, a basement level cast in place tub?
eclark is offline   Reply With Quote
Old 10-03-2012, 09:21 PM   #7
Yup same guy, he just doesn't take advice very well.
Canarywood1 is offline   Reply With Quote
Old 10-03-2012, 10:02 PM   #8
sdsester's Avatar
He does seem intent though. We cannot make them listen. Can you imagine what this concrete basement soak tub is going to look and smell like when everybody suds up and spills their beverages, scewered shrimp and all into the water. No systems for recycling the water through filters or at least copper plates?
Call me a negative person as some on the other thread did. I will say what I did there again though. You cannot plunk anything you plan to splash around in, an especially in your basement without thinking through---just to start---ways to get water in and out of it legally.
Call a pool or spa design team in for this. I find this self-poured concrete tub without reinforced walls to be one of the most dumb suggestions ever floated on this site. The OP will stick with us until he gets affirmation I am guessing.
Old 10-04-2012, 08:47 AM   #9
Im still waiting on PICS
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
Waterproofing under wall on concrete slab JustADoc Carpentry 2 07-18-2011 07:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General Discussion 9 04-11-2010 07:11 AM
Waterproofing an older concrete foundation rapsonite Building & Construction 4 07-20-2008 07:44 AM
