Waterproof Pool Bottom Drain? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-20-2012, 03:17 PM   #1
Stay-at-home GC
Anyone have any experience, tips or resources on setting Pool Drains in concrete?
I am doing a Koi Pond with a Bottom Drain. Something similar to this
All of the resources I find seem to apply to locking the collar to a EPDM liner.
The closest I could get was this link here
Seems the smart money would be on some type of hydraulic cement "ring" around the body of the drain to create a gasket effect but I don't see anyone recommending that.
I'll be on a 4" slab over gravel followed up by a top coat of Xypex Megamix WP cement.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-21-2012, 07:29 AM   #2
DIY staff
Rewards Points: 7,174
Is that designed to clamp onto a rubber or PVC membrane?
Not sure that's the correct drain for concrete installation.
I've never built a concrete pond--only helped with a rubber lined one---
Look at Latacretes site---Hydroban---paint on waterproofing for pomd--pools and showers.
A concrete worker will chime in soon---Mike---
Old 04-23-2012, 07:52 AM   #3
Stay-at-home GC
Thanks Mike,
Yes, that particular model I linked to has a locking collar that clamps down but I believe there are a lot of pond guys that are using it in concrete.
They are setting the fixed part of the bezel level with the concrete and then parging their waterproofing layer over the top of it.
Seems to me, there should be some sort of waterproof ring around the body of the drain. Similar to bentonite clay or rubber gasket between a footing and a poured concrete wall, that swells when water contacts it.
Don't know though, first pool.
Old 04-23-2012, 08:47 AM   #4
Stay-at-home GC
Thank you, William Spence's Construction Materials, Methods and Techniques 2nd Ed.
http://buildingmaterials.cetco.com/D...=10&TabId=1676
Officially referred to as Strip Applied Waterstop Systems
Pool parts...what is this for? tripflex Plumbing 5 02-17-2012 07:32 AM
cement for pool drain leak jerryls Building & Construction 3 06-04-2011 01:52 PM
Grate Drain at Bottom of Steps sloojoe Building & Construction 0 05-02-2011 02:10 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
