Waterproof Concrete Floor To Wall Molding - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-09-2012, 04:52 PM   #1
Rewards Points: 91
waterproof concrete floor to wall molding
Its leaking badly inside garage under wall into finished room.
Its mostly the garage door rubber seal that lets the water into the garage. I've ordered a new one, but I would also like to seal the wall-floor interface to offer insurance against it leaking into the other room again. I cleaned it out as much as possible, but its not super clean. Im attaching some pictures. Any ideas what I can pour into this area?
If I can find something that I can use while its still damp, that would be great. Its now rainy season.
Arrows where it leaks. X is where garage door contacts floor, where most water gets in.
tx,
pa
waterproof concrete floor to wall molding-leak-kay-1-.jpg   waterproof concrete floor to wall molding-leak-kay-2-.jpg   waterproof concrete floor to wall molding-leak-kay.jpg
paulmars is offline   Reply With Quote
Old 07-09-2012, 06:00 PM   #2
Rewards Points: 12,804
Unless you change the grade outside of that door, or add some form of grate with a drain there's is no way to "seal" that mess up.
That's been going on for a while, I'd bet if you cut out that sheetrock by now there's wet insulation and black mold in there.
Replacing the seal will do nothing.
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 07:46 AM
Drywall on interior concrete basement wall marlenec Drywall & Plaster 1 07-18-2011 11:22 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 09:56 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Make waterproof barrier between plywood wall and concrete foundation. gbradley Building & Construction 1 10-24-2010 02:48 PM
