Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-10-2013, 07:41 PM   #1
Water leaking in the basement
I have recently noticed water leaking in my basement over the top of my concrete foundation. Closer inspection of the outside directly above where the water is coming in shows that the top of the concrete foundation wall is well above grade, I also noticed that there is a plastic membrain laying over the edge that of the concrete that runs back behind the bricks. It appears that the plastic may be channeling the water back towards the house and thus into the basement. Can I trim this membrain back flush with the brick? Does this area need to be flashed or waterproofed with something?
Mlorek is offline   Reply With Quote
Old 03-10-2013, 07:43 PM   #2
Another pic from inside directly below
Old 03-10-2013, 07:44 PM   #3
Sorry meant to post this of the outside
Old 03-10-2013, 07:51 PM   #4
And a closer view of that membrain
Old 03-10-2013, 08:49 PM   #5
U definitely need some kind of drip cap flashing. It should have been installed behind the stone and the membrane tucked under the flashing. So any water running down the stone hits the cap and directs it away from getting behind that membrane. That's definitely where your leak is coming from.
smyers is offline   Reply With Quote
Old 03-10-2013, 09:10 PM   #6
Is that something I can get done after the fact? What about using a angle grinder to cut a Channel along the junction of the foundation and brick and then slide in a piece of angle flashing, then caulk it in?
Old 03-10-2013, 09:41 PM   #7
my neck is hurting, AGAIN
i am thinking that i would cut/grind the foundation to an angle that would let the water flow to the outside. but, perhaps cutting the plastic away and caulking would be ok (for a while).
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is online now   Reply With Quote
Old 03-11-2013, 07:06 AM   #8
i'd 1st try trimming that flap & sealing the area ( overbandng the joint ) w/ames' research stuff ( no financial interest ),,, NEVER use caulk - use a proper jnt sealant IF you must !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 03-11-2013, 07:48 AM   #9
My head hurts when I tilt sideways this morning.
Go back to your posts with your photos and remove the photos, edit them by rotating so that they are in the correct orientation.
Or leave as is.
hammerlane is online now   Reply With Quote
Old 03-11-2013, 09:16 AM   #10
Where is the water coming from. Correct that.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 03-11-2013, 06:58 PM   #11
Thanks all for the replies and I apologize for the sore necks. That is the front of my house, there are gutters on the second story above it but no way of stopping rainfall from hitting it. I'm thinking about trimming that membrain back and seeing if that helps. If anyone else has any other ideas pleas let me know, thanks for all the help guys.
Old 03-12-2013, 05:47 AM   #12
drippage from the structure's face causes problems like water under the sill plate,,, we do this for a living & that's our 1st direction - good luck !
sent from my chiropractor's office
Old 03-12-2013, 06:37 AM   #13
Why not take a hose and spray that membrane and see if the leak develops.
Old 03-12-2013, 06:48 AM   #14
Is the window directly above where the leak develops?
Is the home all brick construction or is the side in post #3 brick veneer?
Does the leak develop during any rain or only during a wind driven rain?
Old 03-12-2013, 10:23 AM   #15
Exterior Construction
Windows on Wash's Avatar
That sill looks nearly flat as well.
Have you check the drainage pipe for obstruction or incompleteness underground?
+1 on the other feedback as it pertains to the membrane.
Basement Sump Pump for Roof Water housefixr Plumbing 4 08-26-2012 10:39 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 07:24 PM
stop water from leaking into basement? njhomer General Discussion 5 01-26-2009 11:03 AM
Water in the basement - help! jkrodger Building & Construction 6 03-19-2008 04:25 PM
