Water Damaged Stucco - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-26-2014, 09:15 AM   #1
Not sure if I'm posting in the right place, but any advice you guys can provide is greatly appreciated.
Bought a house as-is, pulled up the dead flowers and weeds that the owner watered to death for years and then stopped watering once they accepted our offer, and unveiled stucco damage around the bottom perimeter of the house a week after we got the keys.
Home built in: 1958
How should we go about tackling this stucco and paint? Do we have to re-stucco the entire home in order for the paint to look good? Or will fixing the stucco around the bottom
perimeter be enough.
via iPhone
oxocode is offline   Reply With Quote
Old 05-26-2014, 01:18 PM   #2
Registered User
Rewards Points: 526
IMHO, pave-over the flowerbeds, Photo/fig. #6; http://www.buildingscience.com/docum...sture-problems
You may have wood framing behind the stucco (water reservoir) siding; #5; http://publicecodes.cyberregs.com/ic...?bu2=undefined
As you repair the stucco, add two layers of WRB for better protection; http://www.buildingscience.com/docum...d-wall-systems
http://www.buildingscience.com/docum...-perfect-storm
One of our forum experts should be along shortly....
Gary
PS. Welcome to the forums!
The Following User Says Thank You to Gary in WA For This Useful Post:
Hot water from cold pipes, plumbers are stumped seabeast Plumbing 75 03-31-2015 09:52 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
