Wash Out Under House Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-21-2013, 12:57 AM   #1
Rewards Points: 182
Wash out under house slab
Rain water from our elderly neighbor's poorly positioned gutter downspouts have washed out the soil beneath her foundation corner. The washout is about 3' wide x 3' long x 1' deep. Must have been going on for years. Aside from changing the down spouts location I know the soil must be replaced. Other than that is there anything else that should be done?
sore thumb is offline   Reply With Quote
Old 04-21-2013, 05:55 AM   #2
Rewards Points: 4,442
might suggest to her she walk around her house at least more'n once every year probably no different that what you've mentioned,,, compact it as best you can w/2x4 & that'd be it
how'd your d/w turn out ?
Old 04-21-2013, 08:32 AM   #3
Rewards Points: 182
Thanks friend. Neighbor lady didn't even notice it! I found the washout while looking at our new fence from her yard!
The driveway. At our request the LS contractor stopped tring to strip the H&C off. He compensated us by moving to the front yard and working. The H&C is off sparatically around the entire drive. I got two bids for removal and simple sealing $$$$. Did discover a common gel stripper from Ace Hardware that works great (DW is sloped). I'm going to use it on the sidewalk portion to get that portion cleared. As for the rest, it may have to wait for awhile. Good thing the H&C color fainted so much.
Old 04-21-2013, 10:17 PM   #4
good to hear & THANKS for the tip,,, we pro's don't usually think of regular h-ware stores since the apron/vest kids have run 'em out of biz,,, think we still have 1 hereabouts in ga - will grab up some tomorrow for a test.
good luck !
The Following User Says Thank You to stadry For This Useful Post:
sore thumb (04-22-2013)
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 8 12-23-2012 12:35 PM
Sewer line under the slab or embedded in it? (1950's house, MN) buckybadger Plumbing 2 10-27-2011 01:45 PM
inside sewer clean out slab house jeff5150 Plumbing 1 03-27-2011 08:37 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 11:01 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
