#1 |
Want to use crushed brick as a base for concrete patio
Hi, I am currently in the middle of building my new home. The masons just finished and left me a yard full of broken bricks.
I need to build a small 8x10 slab that ranges from 4 inched deep to 15 inches deep, (slope of the land) and I remember hearing that crushed brick is a good base for concrete. So I payed my nephew to help me collect all the broke bricks and cart them over to the area where I want the patio. We then proceeded to smash them into small pieces so they have nice jagged edges and compact nicely. I was about to call the cement trucks but I though I would sound it out here first. Does anyone have any experience using old bricks as a filler/base? By the way, I should mention that the ground beneath the patio is nearly solid rock. Not rocks, rock. Like large Volkswagen-sized rock, so I am not worried about ground stability. I mainly thought this might be a way to use less concrete. Any advice would be appreciated. |
#2 |
Master General ReEngineer
Ayuh,.... As long as they're compacted, I don't see any problem...
#3 |
Civil Engineer
As long as the brick you are using was outdoor rated, no problem. Interior only rated brick is not going to last very long exposed to freeze/thaw.
| The Following User Says Thank You to Daniel Holzman For This Useful Post: | matkyne (04-30-2012) |
#4 |
The bricks were the remnants from the brick veneer installed on the exterior of my home; so they should be good to go. Just as a follow up, in case anyone else is considering doing the same thing... ... all the work, collecting and smashing the bricks took about 6 hours. For the help I paid my nephew $45 bucks and bought him lunch ($12). And for all my effort and expense, I probably saved myself $100 in concrete. So I spent 6 hours of back breaking labor to save less than $50. In hindsight, I don't think I would do it again.
#5 | |
Want to use crushed brick as a base for concrete patioQuote:
#6 |
Concrete & Masonry
You know you could have used cheap aggregate, like gravel as well, don't you? No need to ever pour concrete flatwork that thick just because the grade is low.....
| The Following User Says Thank You to jomama45 For This Useful Post: | concretemasonry (04-30-2012) |
| Tags |
concrete, old brick, patio ![]() |
| Display Modes | |
| Brick veneer is 4 rows below grade- redo or leave? | cbrc5eric | Building & Construction | 11 | 12-27-2011 09:09 PM |
| How much sub base for patio? | Reiguy | Landscaping & Lawn Care | 17 | 03-23-2011 09:46 PM |
| Interlocking brick patio | hell167 | Landscaping & Lawn Care | 8 | 02-28-2011 05:00 PM |
| Paver Patio Prep, base amounts | bartic | Landscaping & Lawn Care | 4 | 05-29-2008 10:01 AM |
| Steps on an umortated brick patio | schott_robert | Building & Construction | 2 | 12-04-2006 08:15 AM |
