Want To Fill Old Hot Tub Hole In Basement. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-01-2013, 12:15 PM   #1
Want to fill old hot tub hole in basement.
I've got an 11'x10'3"x2' hole in my basement from a previous owner who wanted to install a hot tub of sorts. It's concreted on the sides and bottom.
I want to fill the hole and lay a concrete slab on top so I can put down carpet and have a regular room instead of a room with a hole.
What should i fill the hole with?
Sand, gravel? A mix?
How thick should my final slab be and do i need to support it with rebar?
The rest of the room is concrete.
Thanks!
konacj is offline   Reply With Quote
Old 08-01-2013, 02:19 PM   #2
joed's Avatar
Rewards Points: 12,002
I would fill it is stone and pour a 4" slab on top. A few rebar pins into the existing floor will keep the new slab level if the stone settles underneath. I have also seen this done with no fill underneath. Build a platform with plywood on top and pour the slab. Rebar pins are required for this option.
Old 08-01-2013, 02:25 PM   #3
How is best to set those rebar pins? Do I drill into the concrete below and simply place them, or do they go flush on the concrete as it lays?
Old 08-01-2013, 02:27 PM   #4
Rewards Points: 4,534
bank run or washed gravel would be my choice,,, you should place the fill in compact'd ' llifts ' ( layers ),,, i'd choose 6" lifts depending on the suitability of the mtl
rebar adds flexural strength to the patch but not compressive strength,,, consider installing #4 horizontal bars grouted into drilled horizontal holes into the existing slab,,, i'd also install a vapor barrier under the conc ( on top of the compact'd fill ),,, that's almost 7cy of fill + 113sf of 4" conc,,, it'll deep you out of trouble for several days place the new floor at the same thickness as the existing floor.
good luck !
Old 07-09-2015, 08:56 PM   #5
How do I backfill old concrete hot tub with out taking out an cap it with 4in. Cement to match existing patio slab
Maximus275 is offline   Reply With Quote
Old 07-10-2015, 08:19 AM   #6
joed's Avatar
Two year old thread.
Old 07-10-2015, 09:47 PM   #7
but its yesterday's inquiry,,, same way - fill w/gravel & mix bagg'd conc to be 4" thick,,, you can't match existing UNLESS you overlay the whole slab
cutting a hole in basement floor for toilet lrkramer001 Plumbing 1 01-15-2011 02:30 PM
Filling a large hole in basement! rotteneggz Building & Construction 4 10-01-2010 07:11 PM
taking out wood stove how to fill hole. bowanna03 General DIY Discussions 6 06-16-2009 10:46 PM
hole for basement bathroom vent location jeeper Building & Construction 4 04-12-2009 12:25 PM
A hole in the basement wall handifoot Building & Construction 10 01-08-2009 10:14 AM
