Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-15-2012, 04:21 PM   #1
vapor barrier under concrete slab
I'm pouring my basement floor/slab in a few days and I had a question. My architect recommended a 10 mil sheet of poly under the slab as a vapor barrier. I'm not going to be able to get a 10 mil sheet by that time but I was wondering if it would be ok if I took two 6 mil sheets and used some sort of silicon around the edges to basically seal them as one sheet. Would this double ply 6 mil basically be the same as a 12 mil sheet (assuming I can keep the moisture from getting in between the 2 sheets)?
DIY1 is offline   Reply With Quote
Old 08-15-2012, 05:18 PM   #2
World's Tallest Midget
Mort's Avatar
How come you can't get the 10mm? We have 10mm at work, and haul it to jobs all the time. Call your concrete supplier and see if they have any.
Mort is offline   Reply With Quote
Old 08-15-2012, 11:24 PM   #3
Yeah, you can do the two layers if you must.
cleveman is offline   Reply With Quote
Old 08-15-2012, 11:32 PM   #4
Two layers will work and there's no need to try and use silicon.
Old 08-16-2012, 10:40 AM   #5
Concrete & Masonry
Ditto...........
jomama45 is offline   Reply With Quote
Old 08-18-2012, 12:16 AM   #6
Moderator
Don't sweat the small stuff; http://www.greenbuildingadvisor.com/...cience-podcast
This was next to that one in my library; http://www.nrmca.org/aboutconcrete/cips/29p.pdf
And the perimeter insulation per code, if in a heating climate; http://www.buildingscience.com/docum...059-slab-happy
Gary
Clothes taking longer to dry?
Old 08-19-2012, 07:29 PM   #7
Cant they invent insulated concrete?
TRUEPRO is offline   Reply With Quote
Old 08-20-2012, 10:34 AM   #8
Mort's Avatar
I'm going to invent self-heating concrete, so I don't have to drive on friggin' snow for 4-5 months out of the year.
Old 08-20-2012, 11:10 AM   #9
Electricity heats the roads, heat melts the ice, melted snow drains in reservoir, reservoir feeds turbine, turbine sends electricity to power road heat. Genius
Tags
basement floor, concrete, slab
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
