Using Two Different Kinds Of Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-01-2012, 03:38 PM   #1
Rewards Points: 93
Using two different kinds of concrete
I am filling holes in my basement concrete floor. When i asked for info at the hardware store the guy sold me "sand mix" concrete because it doesnt contain aggregate so it does a smoother finish. Makes sence! Problem is when i got home i noticed that I cant go over 2" with the sand mix.
So i was thinking i was going to get concrete with stone to fill up most of the hole up to maybe 1.5" then top it off right away with the sand mix concrete.
Is this a good idea?
simonb is offline   Reply With Quote
Old 08-01-2012, 04:35 PM   #2
Rewards Points: 502
The mix seems about right, but just make sure you order plenty so that you don't run short. Always better to have too much concrete than too little, I say - you can always re-lay the drive or build a pool if you find you have a bit left over. Don't buy the stuff in bags either- that's for cissies.
tony.g is offline   Reply With Quote
Old 08-01-2012, 04:56 PM   #3
Rewards Points: 93
I'm going to be ussing bags because the job is very small and at most I will need 4 bags total. Not worth getting a truck
Old 08-01-2012, 05:00 PM   #4
Rewards Points: 502
Oh,...er, ok then.
Old 08-02-2012, 03:26 PM   #5
Rewards Points: 93
Anyone else?
Is using 2 different concrete mix back to back with no dry time a bad idea?
Old 08-02-2012, 03:37 PM   #6
concretemasonry's Avatar
Rewards Points: 2,578
You can dump one type over the other while still wet and then finish. Also, use a rebar or broom handle before finishing to rod or blend the 2 layers together somewhat.
You do not dry out concrete because it takes moisture and time to cure and work together. Keep it damp for a while.
Dick
concretemasonry is offline   Reply With Quote
Old 08-02-2012, 03:56 PM   #7
Rewards Points: 502
After he's put the first layer down, would it help if he pressed some strips of expanded metal lath onto it, and then applied the top layer?
Old 08-02-2012, 05:33 PM   #8
Not much good and the metal lath may interfere with the two layers mixing and bonding together.
It is only a thin layer for leveling. For patching holes in a basement, just a normal concrete mix would be adequate, depending on the criterial for the finish.
Dick
Old 08-02-2012, 05:53 PM   #9
Rewards Points: 582
Floor screeds 3 inch thick of sharp sand/cement are put on top of 4 inch thick concrete floors here, although as Dick said you should be able to get a decent finish with normal concrete for a hole patch.
stuart45 is offline   Reply With Quote
Old 08-03-2012, 12:14 AM   #10
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Yeah, I don't see a reason to use a sand mix. The whole rest of your floor has aggregate in it.
Mort is online now   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How to smooth a rough aggate concrete floor lotstodo Flooring 1 08-18-2008 10:23 PM
