Using Regular Drill For Tapcon Concrete Screws? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-09-2012, 07:01 PM   #1
Rewards Points: 213
Using regular drill for tapcon concrete screws?
My drill seemed to work in putting the holes in the concrete. bolting toilet flange to concrete
Then I reread the directions saying only to use hammer drill
I only have a regular drill and an impact driver. Could I use one of these for putting the tapcon screw in? I don't want to spend money on hammer drill. This is
crayola110 is offline   Reply With Quote
Old 10-09-2012, 07:19 PM   #2
Rewards Points: 14,026
I've never seen a masonry bit with a 1/4 hex shank that would work in a impact driver.
It's not going to do any harm to use a reguler drill just going to take 4 times at least to drill the hole. You should also keep stoping to suck out the dust,
Old 10-09-2012, 08:09 PM   #3
Rewards Points: 3,744
I think they mean to use a hammer drill to bore the holes for the tapcon,not to drive the screw itself,but i don't think i'd use an impact driver for the screw,might strip it out.
Canarywood1 is online now   Reply With Quote
Old 10-09-2012, 08:13 PM   #4
I always drive my Tap-Con screws with my impact drive.
Old 10-09-2012, 08:48 PM   #5
DIY staff
Rewards Points: 7,174
Hammer drills are used to drill the holes---using a standard drill will work---but the bits over heat and will not give you many holes.
You are fine---If you ever need to drill a lot of holes in masonry---then buy the hammer drill---
Old 10-10-2012, 03:41 PM   #6
Rewards Points: 213
Oh I see. So the Hammer is for the Holes.
It did take me a long time to drill with my regular drill. Luckily the screws did not overheat as I kept dipping the drill bit in water.
I'll just use my regular drill to install the Tapcon screws now
sorry, i am so confused about the different drills and what they're used for....
Thanks so much as always!
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 04:15 PM
Best drill bit for old concrete johnjack11 Concrete, Stone & Masonry 22 03-14-2012 03:27 PM
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 07:00 PM
is there an concrete epoxy that can be used with regular caulk gun rocketdoctor Building & Construction 8 06-02-2011 08:57 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
